SC GE going into an IS
Here's the deal, my buddy bought an IS chassis and we wanna put my SC's 2jzge in it. What motor mount brackets should we use? Do we have to use the IS vvti upper and lower oil pan? Is that pan different than the aristo front sump pan that we are using? The IS brackets don't seem to wanna line up with the GE block. I know people have put GTE's in IS and my GE should be the same type of swap, right? Can anyone give some advice?
Originally Posted by 7sins
(Post 6030648)
Right now we are using IS motor mount brackets and IS motor mounts with an Aristo upper and lower oil pan. With the IS mounts and brackets the engine sits about 2" to far forward. Keep in mind this is a non vvti engine! Only 2 bolt holes line up on the driver side engine mount bracket.
