IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Help me with a tire problem
Old 06-20-10, 01:16 PM
JSwenis
JSwenis's Avatar
Question Help me with a tire problem
Let's start this off by saying i have 0 exp and knowledge about this topic so i'm ready for the critism.
I had stock "17 rims on my '02 and traded them out with a guy down the street that had some "18 Racing Hart's. Now whenever i make sharp turns or hit some pot holes, dip, or speed bump i get a fairly loud rubbing sound . When i turn the sound is from the front, when i dip its from the back. Now it doesn't look like it's hitting. What are some of my options. Thanks for any help.
Old 06-20-10, 06:04 PM
AltezzaIS3
AltezzaIS3's Avatar
On the inside of your fender there is about an inch that goes into the wheel well. shave thatall with a dremel or some other tool. This modification is not noticeable from the exterior.
Another option is to roll your fenders. Go to a local mechanic or whatever and tell them your situation and see if they will roll your fenders.
Old 06-20-10, 06:08 PM
tjmhillz
tjmhillz's Avatar
sounds like you need to roll your fenders. what are the specs of the wheels.
Old 06-20-10, 07:21 PM
JSwenis
JSwenis's Avatar
Thanks for the options. Im gonna look into rolling the fenders.
Thanks for the input. Im not sure what the width is on the rims. My rubbers are 215/40/ZR18's in the front and 245/40/ZR18's in the rear.
Old 06-20-10, 09:05 PM
sugzz
sugzz's Avatar
With the size tire your running in the front your probably just rubbing the the fender liner. What you can do is mask off the liner with tape, then drive the car around for a little while. The tire will rub the tape off where its hitting. Now that you know where its rubbing use a heat gun and heat the liner up, when its gets warm enough get a cold towel and push it back.
For the rear, all you have to do is roll your fenders.... Good Luck.
Old 06-21-10, 05:15 PM
twestman
twestman's Avatar
A 245/40 is a wicked tall tire on an IS... That is most likely where all your rubbing is originating from.
Old 06-21-10, 05:29 PM
JSwenis
JSwenis's Avatar
I found the rub in the front and it is fixed. Thank you.
Very true. when i got the wheels off the trade the rubbers were already on them. im gonna get some 215/40's and see if that helps before i roll the fenders.
ItsanF
IS F (2008-2014)
12
03-20-13 09:53 PM
branddz
02-10-10 12:45 AM
CptCrunch
07-13-08 09:39 PM
ewenpg
07-27-07 10:26 PM
IcEnPinKi
13
04-10-05 08:54 AM
Quick Reply: Help me with a tire problem
