IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
No crank
Old Mar 15, 2024 | 11:47 AM
Kumarsaber's Avatar
Kumarsaber
10th Gear
Unhappy No crank
Hi everyone.
I recently replaced the engine in my 2005 is300. I refreshed the new engine with new parts. But now that the engine is in the car, it won't crank! I made sure all grounding points were clean when I reinstalled everything, by clean I mean I wire-wheeled the contact points on both ends of the ground. I inspected the main 20A fuse, and it's fine. The 120A fuse is fine. I was checking the starter wire and it sparked on me haha so I know that is fine. The connector to the starter clicked into place with no problem. So I'm lost on where to test from here. Please help!
Old Mar 16, 2024 | 03:17 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
Check your throttle body connections. The ECU will disengage the starter with no signal from it.
Old Mar 16, 2024 | 11:08 AM
1997Soarer's Avatar
1997Soarer
The engine you replaced, was it from another 05 IS300 or something else?
And just in case, go over every connector on that wiring harness and make sure it is securely connected. Sometimes a connector feels seated but its not, so the contacts are not touching.
I am pretty sure my car won't crank over if something as simple as my MAF is unplugged.
Old Mar 17, 2024 | 03:15 PM
Kumarsaber's Avatar
Kumarsaber
10th Gear
I’ve checked all wires to the throttle body and there are no issues there
Old Mar 17, 2024 | 04:42 PM
Kumarsaber's Avatar
Kumarsaber
10th Gear
Default Jump started the starter.
UPDATE:
I jump started the started and it cranked, I did this by running a wire from the connector to the main starter wire. So that’s helping me narrow it down. The starter connector is not getting any current.
Do you guys have any idea of what might cause this?
Bad Key?
Faulty wiring.
help
Old Mar 17, 2024 | 06:43 PM
Are you using the original engine computer and harness? Could be a security lock out.
Old Mar 17, 2024 | 07:39 PM
Kumarsaber's Avatar
Kumarsaber
10th Gear
Default Fixed!
Thank you guys for your help! I figured out my problem.
I installed the shifter linkage incorrectly…. I know.. what a amateur hahaha. But it wasn’t fully extended when I bulged it down so the car wasn’t in park whenever I shifted it to park. After I fixed that, the car started right up!
don’t make the same mistake as me guys!
Old Mar 17, 2024 | 07:40 PM
Kumarsaber's Avatar
Kumarsaber
10th Gear
yes I used original wiring harness and ecu.
Old Mar 17, 2024 | 07:48 PM
Easy fix good to hear.
Almasy
Jan 16, 2021 07:01 PM
93sc400guy
May 6, 2017 10:31 AM
Dimashab
May 14, 2014 08:35 PM
pandulce
Jan 3, 2009 08:33 PM
Tranman
Oct 3, 2005 03:26 PM
