2014 ES300h - Dash Cam - Battery Drain - Noco Battery Tender
Hello all,
My wife's car has a Viofo dash cam installed with that detects voltage and cuts off the camera so it doesn't drain the battery. I don't remember what setting it was set at, but it's been 3 years since it was installed and I recently noticed that it was not powered on anymore whenever I get into the car after we have left it parked for a bit while out and about. I also usually have it unplugged when parked inside our home garage each night so as to avoid unnecessary use. Up until now, it still functions just fine when we are driving, so I am assuming the battery has gotten to the shut off level that the hardwire kit is set at. I want to recharge the battery to full capacity using a that I just got. Will it just be the regular 12v option or do we have the AGM batteries? Should I also just leave it in the trunk or is it fine to just remove the battery and charge it while on my garage floor?
LexusK
Nov 21, 2022 04:21 AM
