Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 4GS forum for discussion about shared components with other fourth generation GS models.
EV Mode Unavailable in 110°+ Ambient Temperature
Old Jul 28, 2022 | 05:34 AM
bclexus's Avatar
bclexus
Originally Posted by Im2bz2p345
Just to clarify, the Lexus GSh uses an electric compressor. There is high voltage from the batteries that go to a 3 phase inverter, which modulates voltage to control the speed of the A/C motor.
Toyota and Lexus hybrids vehicles can run when the ICE is completely off (you can witness yourself if you're still in traffic/going through a car wash/etc where your batteries have adequate charge, the ICE will remain off yet you'll still get A/C air).
Here is an older PDF that describes how it worked on older Toyota and Lexus models: https://opensiuc.lib.siu.edu/cgi/vie...text=auto_pres
If you're rather watch a YouTube video, this is a lot more recent and covers the topic well: https://www.youtube.com/watch?v=7unan5rgPwY
Hope that helps,
~ im2bz2p345
Very interesting! I had no idea the electrically driven A/C scroll compressor is actually powered by the traction battery's DC high voltage that is converted to 3 phase AC voltage that can then easily be varied to control the speed of the compressor's motor. That makes sense considering the ECO drive mode can reduce or vary the compressor's speed by signals from the combination of the drive mode and the A/C system control. I guess the delay in the ICE starting in conjunction with the delay in the A/C starting is likely just an intended systems operation process. I'm glad there are intelligent automotive design engineers that can invent these types of things for us. Thanks for the information and video about it!
Literally!
Old Aug 9, 2022 | 11:36 AM
spineman's Avatar
spineman
Originally Posted by Hues10
Somewhat related to the ICE turning over when I first start the car after it sitting overnight. I can shut off the engine with 5 or more bars showing, then in the morning in normal Florida temperatures of 80 degrees, the ICE starts whether I have the AC on or not. So the Hybrid battery is not too cold or warm, but yet the ICE will start. Now if I stop at a store and 20 minutes later start the car, the ICE does not kick in. So explain that my hybrid friends. I just took it as the Coolant and/or oil has to be at a certain temperature for the ICE not to kick in. Thanks.
Yes...I believe you are correct. If the engine is warm and the A/C is off, it has no need to start the ICE to warm up the engine, but it will always start the ICE if it not warmed up.
bclexus
Hybrid Technology
13
Jun 21, 2022 05:01 PM
bassamp
CT 200h Model (2011-2017)
Mar 28, 2016 06:45 AM
bam
Hybrid Technology
Jan 11, 2013 03:21 PM
ziggyziggy
Hybrid Technology
15
Feb 5, 2012 02:46 PM
BinaryJay
Jan 11, 2011 04:58 PM
