Starter Motor
No switch to run on electric only.
AC Compressor will run via electric but it has to be “Ready” ON mode.
The starter motor is an integral part of the ICE, directly behind and in-line with the ICE flywheel. It is driven by 600v from the traction battery under the rear seats, so spinning the ICE up takes just a fraction of a second. The A/C and the power steering are electric and completely independent of the ICE. This last characteristic makes the Toyota hybrids different from the other manufacturers who offer "start-stop," where the ICE is shut down at traffic lights. Startup with those is much more obvious and A/C refrigerant stops circulating with the ICE off, so those systems fire things back up from time to time to cool down the A/C output.
The starter motor is an integral part of the ICE, directly behind and in-line with the ICE flywheel. It is driven by 600v from the traction battery under the rear seats, so spinning the ICE up takes just a fraction of a second. The A/C and the power steering are electric and completely independent of the ICE. This last characteristic makes the Toyota hybrids different from the other manufacturers who offer "start-stop," where the ICE is shut down at traffic lights. Startup with these is much more obvious and A/C refrigerant stops circulating with the ICE off, so those systems fire things back up from time to time to cool down the A/C output.
Regarding your original question, Yes, you can move in and out of a garage on electric power only, I do it all the time. BUT!!! This depends a lot of temperature. If the ambient temp is really cold the system will start the engine soon, sometimes immediately. If warm, the system will not start the engine immediately, but ALWAYS will within about 5 seconds. So you have to get in/out of garage and shut down within 5 seconds to avoid a start (and provided your driveway is level). When you put your foot on the gas pedal to move in and out of the garage, again depending on temp, if its cold out that might trigger an immediate engine start, if its warm out it will let you apply a bit more pressure without triggering an engine start. Short version, in summer its easy, in winter its hard to do.
FYI, the hybrid battery is a NiMH battery not lithium.
