ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   2014 ES300h LED headlights (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/934772-2014-es300h-led-headlights.html)
willyritch Dec 30, 2019 11:40 AM
We have a 2014 ES300h and one of the LED low beam headlights isn't working. It looks like a sealed unit and I don't see how I can replace just the bulb. (And yes--the low beams are definitely LED.)
We bought the car used and it came with the Lexus Platinum warranty--which covers things like the headlight relay but not the bulb. We've got the car at the dealer with the hopes that it's something that will be covered under that fancy warranty. If not, it looks like having the dealer replace the sealed unit could be around $1500. Anyone had any experience here--getting the headlight replaced under warranty or a DIY replacement with parts from Ebay?
Thanks.
Bylan Dec 30, 2019 12:00 PM
https://cimg6.ibsrv.net/gimg/www.clu...dd1726fce3.png
As far as I can tell, the low-beam headlights are not LED's but rather Optional HID's. The daytime-running-lights are LED's.
willyritch Dec 30, 2019 12:38 PM
Bylan is exactly right--it is an HID headlight so the bulb is replaceable. For some reason I can't find an aftermarket bulb listed anywhere but at least it's not an entire assembly.
TechNut Dec 30, 2019 08:54 PM
There are many sources for a replacement bulb - such as https://www.carid.com/oracle-lightin...654604069.html. This was just one quick place I checked so I do not know if the price is competitive. It sounds pretty high to me...
abrown0809 Dec 31, 2019 06:15 AM
I just replaced the HID bulbs in my 2015 ES. They are D4S type HID bulbs. Lightwerkz or The Retrofit Source is a good place to get them. Make sure you replace both the left and right sides do you have the same color and light output. You only have to twist and remove the back circular cover to access the bulbs. Getting them out and especially back in can be super tricky and frustrating. Consider having the dealer do the replacement.
norakat Jan 3, 2020 01:44 PM
So what is the verdict on this?
My headlight is sealed (no twist cap) for the low beam headlight. I am thinking it is LED after all. I can't believe they expect you unseal the headlight just to change a bulb.
12jimmyjam Jan 3, 2020 05:32 PM
https://cimg3.ibsrv.net/gimg/www.clu...b21eb4f4a0.png
It’s HID/xenon.
https://pressroom.lexus.com/2014-lex...-hybrid-sedan/
st1800 Jan 3, 2020 07:59 PM
norakat Jan 3, 2020 08:13 PM
Oh I didn’t realize this post was titled 2014 ES..
My car is a 2016 ES 350 Luxury Edition. I think mine is LED.
jjchicago Mar 28, 2021 01:43 PM
is yours the 300h. big differece the hybrid gas battery and electric motor in front
Wojtek03 Apr 3, 2021 02:14 PM
You should be able to access the headlight bulb. I have a 2014 es 350 and replaced my low beam headlights with LED lights. Here is a video I watched to help me do it, hope this helps.
garrickm Jun 30, 2021 12:51 AM
how much dis
toy have to remove to get to the bulb cover?
samsonn25 Jun 6, 2023 12:45 AM
2013 ES300h here with 238k miles
Im about to replace the HID on my driver side.
Unlike the passenger side, the driver side looks tight as FCK. Almost no room to remove back end cap, etc.
I see someone posted the front bumper and front fender protector has to be removed, so the headlight assembly can be taken out to access the back, that is crazy!
I will update soon.
Got it done today, tight as hell. Passenger side alot easier, clips still a pain in the ass. Kudos to my mechanic who helped on the driver side line the bulb in correct position the reapply the stupid spring, before twisting the power cap/cord back on,
While we were there I adjusted the Passenger side headlight higher since factory always have the headlights aiming LOW.
is250916 Feb 10, 2024 10:09 AM
Did they had to remove the front bumper to replace the driver side bulb?
LexusK Feb 15, 2024 05:00 AM
Would also like to know. MY 2014 ES300h just recently had the driver side go out. I was planning to take a look tomorrow when I have some time.
