Hybrid Technology Unique topics related to the LS600h L model hybrid drivetrain and other features/options found only on the LS600h. Please use the main 4LS forum for discussion about shared components with other fourth generation LS models.
Ls600h b1861 error
Old Dec 20, 2019 | 01:03 PM
Arpadf189's Avatar
Arpadf189
Default Ls600h b1861 error
I got b1861 error code.
I found a solution but I don't know how can I remove the unit on the following page :
https://www.drive2.ru/l/521802106215072289/
Could you give me any information about it?
Thank you!
Old Dec 20, 2019 | 02:43 PM
LlamaLexus's Avatar
LlamaLexus
Remove all the screws and pull it out.
Old Dec 21, 2019 | 06:45 AM
Arpadf189's Avatar
Arpadf189
Default I found the cable
I removed the panel under the driver side and I found the airbag (knee) plug. Do I have to disconnect the battery negative before I continue the work or not necessary?
What can I do with the plug if I want to repair and go away the error code? Is it a contact issue? How does work this plug? I can pull out or twist any direction?
Old Dec 21, 2019 | 10:38 AM
sha4000's Avatar
sha4000
You should definitely disconnect the negative battery cable and wait a couple of minutes to be safe. What plug are you trying to repair.
roadfrog
Dec 22, 2024 07:23 AM
takadakeyo
Apr 18, 2017 02:07 PM
jjashaa
May 6, 2014 12:39 PM
louiegs400
Aug 21, 2008 06:05 PM
