Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Transmission-p/s
Old 04-14-19, 10:30 PM
tmcr1724
tmcr1724's Avatar
Default Transmission-p/s
HEY GUYS!! COUPLE QUESTIONS,
1. HOW DO I PUT TRANSMISSION FLUID IN MY 2006 RX 400H??
2. After driving over 120 miles today, I needed to go back to the store after about an hour of having my car off.. When I put it in drive, there was a constant beep sound and the display had "P/S" showing as well as BRAKE.
HELP ME AS THIS IS MY FIRST HYBRID
Old 04-15-19, 04:07 PM
thomas1
thomas1's Avatar
You cant check fluid level without going under car. It is set up like a differential. A fill plug and a drain plug.
see this post and you will understand
https://www.clublexus.com/forums/hyb...ial-plugs.html
Old 04-19-19, 05:16 PM
ukrkoz
ukrkoz's Avatar
PS is likely power steering.
You need to read error codes with ABS/brakes capable scanner. Techstream preferred. Regular OBD2 scanner will not read brake, transmission and CAN.BUS codes.
Old 03-08-21, 11:22 AM
iMSQ
iMSQ's Avatar
SJM (04-23-22)
jack19446
09-22-13 07:33 AM
amanda
06-19-12 07:32 PM
funcrusher
12
11-19-10 09:13 AM
uhohitzmik
03-18-09 01:45 PM
RayN
RX - 1st Gen (1999-2003)
11-25-05 09:27 AM
Quick Reply: Transmission-p/s
