Brake system malfunction lights 2012 450H
On 2012 450H with 104000 miles , all brake malfunction lights came on along with ABS malfunction. Brakes seems to be working ok. Is there a recall or TSB on this issue. 450H was bought as CPO
Visit Lexus dealership, as there is no harm in asking politely. If you have been their regular customer for maintenance, they may cover it fully or partially. If there is recall, then that will be done for you.
My understanding about TSB is that they are done free of charge while the vehicle is under warranty (regular/extended). Once the warranty is lapsed then it is not done free of charge.
Salim
Salim
I would get it checked out ASAP. if you drive around with all those faults and the brakes happen to fail after you know about these faults, you could put yourself and others at risk. and could be in a heap of legal trouble if you cause injury or death to someone else. be warned. not worth playing with brakes.
please let us know what the dealer finds.
I took car to private garage connected to code reader, c 1391. He stated that repair would be very expensive . Something wrong with accumulator. Brakes work just like before.
