Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Repeated problem with 2008 RX400h
Old Oct 23, 2025 | 10:05 AM
ivan4784's Avatar
ivan4784
1st Gear
Default Repeated problem with 2008 RX400h
hi recently my Lexus for the second time has done this where three lights pop up. Check AWD System, Check Hybrid System, and Check VSC System. It won’t lets me accelerate correctly and it starts with like a weird engine feeling sort of choppy and you can feel the car shaking a bit. The first time this happened it did all these things again and also shut down at a stop light and I had to start it all over again and it wouldn’t stop trying to turn off. Does anyone have any suggestions? Ballpark numbers of how much it might cost to fix these problems?
Old Oct 24, 2025 | 01:07 AM
789's Avatar
789
4th Gear
Default My experience
I had the various lights come up but everything was working. I changed the starter battery and over the next few days everything went back to normal.
My battery was about 4/5 hrs old and not otherwise playing up but with others saying the battery demise can cause warning lights etc. I renewed it.
not saying this will be your issue but if you check the date code on the battery you might think it might be worth changing.
i had checked everything else, inverter coolant pump ok etc so was a reasonable cost v guess.
certainly £200 for a garage just to plug it in was avoided.
Old Oct 25, 2025 | 03:14 AM
rich1068's Avatar
rich1068
Agreed. Checking the 12V battery would be where I'd start.
Old Nov 5, 2025 | 05:47 AM
highmile5's Avatar
highmile5
you need to get a capable scanner (not the basic obd2) like the Autel MaxiAP which is really cheap and scan for codes, no need to guess on what's going on.
rangel28
NX - 1st Gen (2015-2021)
Oct 13, 2025 05:23 PM
Dan1981
Oct 1, 2024 08:23 AM
kim0217
Oct 30, 2015 04:02 AM
spudboy
Mar 16, 2015 06:17 AM
alwaleedi
Jun 25, 2014 08:04 AM
