Hybrid Technology Unique topics related to the 2022 and up NX hybrid drivetrain and other features/options found only on the NX Hybrid models. Please use the main forum for discussion about shared components with other 2nd generation NX models.
NX350H fuel consumption
Old Jul 21, 2023 | 01:58 PM
  #46
LStoneX's Avatar
LStoneX
Originally Posted by Tarnshoe
Hahah. I’m trying to see how big of a difference does the rim size have in mpg. I have the 20s and I’m only averaging around 35mpg. It seems that those with the 18s can hit 40mpg pretty easily and some go beyond
While rim size matters, I think speed and driving habits have a bigger impact.
My NX wears 20" shoes for summer
Old Jul 21, 2023 | 02:08 PM
  #47
user 082089340294's Avatar
user 082089340294
Guest
Tire Size. Larger tires decrease your fuel economy because they are heavier, while smaller tires increase fuel efficiency. Bigger tires also have a higher rolling resistance than smaller tires which means they require more resistance and effort to get them rolling. U,S, Dept. of Energy
But--apparently if you do a lot of highway driving larger tires can be a mpg advantage. Other variables matter too, e.g. how you drive; what PSI you have in them, etc. All these can make it a close call re: mpg with slight edge to smaller. Smaller tires would usually give a better ride as well.
Old Jul 21, 2023 | 03:01 PM
  #48
Tarnshoe's Avatar
Tarnshoe
@LStoneX I’ve been super light on the pedal since I got my 350h and try use the pulse and glide technique whenever I can. Do you noticed a difference between your winter and summer tires? I know cold weather is not good for mpg so it’s a difficult comparison
@romer that’s some good info. Thank you for that. I have noticed that I’ve been getting better mpg when I’m on the highway which seems to be the opposite of the EPA says (higher in city/ lower on highway). On the highway my mpg is usually in the 40s
Old Jul 21, 2023 | 03:18 PM
  #49
LStoneX's Avatar
LStoneX
There's marked differences in my summer and winter consumption.
If I recall correctly, in the winter, my tank would get me about 650km on every fill up. But I think the engine wasn't fully broken in yet.
I'll wait to see what happens this coming winter and compare. I expect it would drop from the current 900km a tank, but perhaps it'll be closer to 700km than 600km on each tank.
Old Jul 22, 2023 | 06:45 PM
  #50
CaliNXHer's Avatar
CaliNXHer
8th Gear
I have the 20s and also see on average 35mpg in mixed driving
Old Aug 7, 2023 | 04:33 PM
  #51
SeismicGuy's Avatar
SeismicGuy
We've had the car not quite a month now and we just filled it for the first time. Fuel came out to be about 34 MPG. This is probably 80% short local trips on city streets and maybe 20% on the freeway. Also it has been hot here lately so AC has been on all the time.
bladest
Hybrid Technology
22
May 24, 2022 03:23 AM
landonm86
ES - 7th Gen (2019-2025)
27
Mar 13, 2022 08:38 AM
2XLXTN
May 16, 2018 09:36 AM
batchelor
NX - 1st Gen (2015-2021)
Jul 31, 2017 04:12 PM
vvking
Jul 24, 2003 06:59 AM
