HS 250h Model (2010-2012)
Need driver side mirror cover
Old Dec 26, 2018 | 01:29 PM
liweil's Avatar
liweil
Default Need driver side mirror cover
I was backing out of a friend's garage and hit the beam. The shell of the driver side mirror is cracked. Instead of ordering whole new assembly for $300+, some online sites do list the outer cover for about $100. But all the sites I visited have the color (beige) discontinued. All other colors are still available. Part number is 8794A53410E4. I need help to locate the item and if anyone has the diagram how to take it apart. Thank you.
Old Dec 28, 2018 | 03:01 PM
Clutchless's Avatar
Clutchless
I would try eBay and junkyards for a used mirror assembly. Try this large Lexus recycler http://www.rancholexusrecycling.com/
Have you tried lexus south atlanta parts? https://www.lexussouthatlantaparts.com/
You never said what color your car was.
I am sure they are available because body shops can get such parts. If nothing else works, go to a local auto body shop.
Old Jan 5, 2019 | 09:13 PM
Remimn's Avatar
Remimn
Hi, I was wondering if you found. Im also looking for the same part in grey.
Old Jan 9, 2019 | 10:42 AM
liweil's Avatar
liweil
Thanks Clutchless for your recommendation. The color I am looking for is beige and so far no luck. I may just need to replace the whole assembly. Anyone has instruction how to do it myself?
For Remimn, look at this link for other colors: https://parts.lexusofwestkendall.com...utside-mirrors
Old Jan 9, 2019 | 11:02 AM
Remimn's Avatar
Remimn
I just ordered just the shell at the dealership. 70 usd in my color.
Old Jan 9, 2019 | 02:27 PM
Clutchless's Avatar
Clutchless
I would search youtube for Toyota (or Lexus) replace side (or rear) view mirror or maybe repair mirror as Toyotas will be the same as Lexus. More likely to find a Toyota video.
Old Jan 15, 2019 | 02:38 PM
liweil's Avatar
liweil
Remimn, I called some Nor Cal dealers that they had to call So Cal dealers/warehouse to verify the part. They came back to me because Lexus stopped selling this vehicle, no shell (outside cover) or mirror assembly are available at any dealer. Do you mind sharing the info of the dealer where you ordered it from? I was able to pop the mirror to reach all screws to remove the shell. So it's doable and easy.
Old Jan 15, 2019 | 02:56 PM
Remimn's Avatar
Remimn
How did you proceed to remove the mirror? did you pull from the bottom like most lexus?
Heres the delaership info: https://www.lexusgabrielbrossard.com/fr/index
Old Jan 15, 2019 | 03:20 PM
liweil's Avatar
liweil
Follow the beginning of this youtube to remove it. It took me less than 10 minutes to do it. I called another So Cal dealer and they said it shows it's still available in their inventory database but refused to pick up the phone to call the warehouse. Often the on-hand quantity is not accurate but he won't do it. I will place the order online to see if they can get it or not.
Old Jan 15, 2019 | 03:21 PM
Remimn's Avatar
Remimn
i see no youtube vid
Old Jan 15, 2019 | 05:10 PM
liweil's Avatar
liweil
Old Jan 26, 2019 | 12:25 PM
liweil's Avatar
liweil
Here is my update. I ordered a white one since beige is no longer being produced. A local body shop guy painted it for me and I was able to swap out the old one with the new one in 30 minutes. Very easy task. Remimn how did your go?
Old Jan 26, 2019 | 12:28 PM
Remimn's Avatar
Remimn
Mine was very bad.... when I opened the cover, all the frame inside of the actuator was rusted and some part of it was cracked. Need to replace it... cheapest actuator sub i found was 250$... dont feel like dishing that much for such a small part. will wait to see if there are salvage parts...
Old Jan 26, 2019 | 01:05 PM
liweil's Avatar
liweil
Sorry to hear that. My local body shop called salvage lots and the quote he got was higher than new one. That's why I decided to just replace the outside casing. Yours must be leaking. My LED turn signal has a tiny crack that I had to tape it over from letting water going in.
Don't bet on finding a cheap salvage part. I do not believe you will find many in the junk yard. Good luck.
Old Mar 30, 2019 | 04:52 AM
Predneck's Avatar
Predneck
Default Try this site for any used parts
I am an auto adjuster for twenty five years now and used parts are typically about a third of the cost of new.
If it is a painted part like a mirror you can possibly locate one in the same color and small parts like that can be sent UPS relatively cheaply so you can order from anywhere. Paint match may be iffy though due to oxidation, etc. You might still need paint.
Also, often new OEM parts are no longer available in color after first couple of years though the manufacturer might still show them on a parts list. So really almost always a body part requires paint.
Keep in mind if a body shop orders the part for you they will mark it up 25% or even more.
Find a shop agreeable to install a mirror or whatever your dealing with and bring the part. Money saved.
The best site that gives a full listing of parts nationwide and you can sort to your area or by lowest price etc is:
Car-part. com
I will always call and verify the part is "insurance quality" so no damage. If it is a painted part you can verify color and condition.
Remember these are salvage yards so try to negotiate the price as most will.
Just some insight for y'all .
TangoEvo
NX - 1st Gen (2015-2021)
May 16, 2022 08:48 PM
MAizz
Aug 10, 2015 12:16 PM
Gabeshell
Aug 22, 2007 02:16 PM
