HS 250h Model (2010-2012)
12 volt batterey
Old 11-21-17, 09:02 AM
dpham0103
dpham0103's Avatar
Default 12 volt batterey
We have a HS 250H, 2011 model.
The car dead last night and i jumped start her.... I am just wondering where is the 12 volts battery located in the car? i am looking toward to replace it.
thanks a lot
Old 11-21-17, 11:42 AM
nht48823
nht48823's Avatar
The 12 volts battery is located in the back (behind the back seat) - there is little opening in the trunk you have to remove the carpet cover to be able see the latch and you will see the battery
Old 11-23-17, 07:10 PM
Magellan55
Magellan55's Avatar
Just be aware it's not a typical lead-acid battery, as it's exposed to the car interior. It's a gel battery, and likely hard to find outside a Lexus / Toyota dealer. It's also about $250.
Old 04-06-24, 04:13 AM
rolex16233
rolex16233's Avatar
is that possible to upsize the 12v battery?
Old 04-06-24, 07:30 AM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
No, you are limited in space and in type of battery. This is really a dealer only item unless you make modifications to the mounting system as someone has posted here a long time ago. Considering that this is the only time you will have to replace the 12 volt battery as they last 10 years, just bit the bullet and get one from a Toyota or Lexus dealer.
Magellan55 (04-08-24)
2GR
02-05-19 04:03 PM
keldon595
ES - 6th Gen (2013-2018)
05-11-18 11:47 AM
RomanTPA
01-22-17 09:48 AM
adamselene
Hybrid Technology
21
03-30-15 08:22 PM
skelow401
09-06-11 04:36 PM
Quick Reply: 12 volt batterey
