HS 250h Model (2010-2012)
Replace Trunk Latch Actuator and Trunk Release Button
Old Sep 23, 2025 | 12:55 PM
TaylorPup's Avatar
TaylorPup
10th Gear
Default Replace Trunk Latch Actuator and Trunk Release Button
Ok, refurbished hybrid battery is good so far! Fingers and toes crossed.
I'm moving onto the trunk latch issues. I want to see if I can tackle this on my own with my nephew. Has anyone bought the knock-off Actuator and the knock-off Trunk Release switch (the squishy one that turns to goo) from eBay or Amazon? If so, did they work out for you?
I've looked at a few You Tube videos and it doesn't seem that difficult to replace either of these. The only question I have that I'm hoping someone knows the answer to is: Do you have to disconnect the 12V battery to do the replacement?
If there is a previous post about this, my apologies.
Happy Fall from a hot (and muggy) southern California.
Old Sep 26, 2025 | 05:35 AM
Clutchless's Avatar
Clutchless
See these older threads that should provide all the information you need.
​​​​​​https://www.clublexus.com/forums/hs-...se-button.html
​​​​​​https://www.clublexus.com/forums/hs-...on-t-lock.html
​​​​​​https://www.clublexus.com/forums/hs-...nk-locked.html
Old Sep 26, 2025 | 06:18 PM
TaylorPup's Avatar
TaylorPup
10th Gear
I didn't see the answers to my questions in these threads, so if anyone can answer - thank you!
Someone bought a trunk actuator that was not specifically for HS250h. I'm wondering if anyone has bought the knock-offs that are a match!
Old Oct 6, 2025 | 11:23 AM
WNGZRO619's Avatar
WNGZRO619
Hi there TaylorPup. I performed this task and I did not have to disconnect the 12V battery. You can review my post on this task for reference. https://www.clublexus.com/forums/hs-...0h-corner.html.
Old Oct 8, 2025 | 06:12 AM
JRStan75's Avatar
JRStan75
3rd Gear
Default Squishy button
So the squishy button is super easy to swap. That did not fix my issue though. I wonder if it is the button in the cabin. That one is harder to find a replacement for.
Borker
13
Nov 16, 2024 12:11 PM
rickster9
Sep 20, 2024 02:45 PM
ckorbel
May 6, 2024 11:19 PM
lexluver
Oct 6, 2016 05:18 PM
PoxLi
Nov 4, 2013 05:15 PM
