2010-2013 AFS HID headlight adjustments,conversions,component replacements
Old 02-17-23, 11:25 AM
  #121
CFAI
CFAI's Avatar
So get just new stock bulbs and ballasts? I am useless with wrench, so I will need to have a shop do it.
Old 02-18-23, 10:20 PM
  #122
WRD4chano
WRD4chano's Avatar
I went with the osram night breakers(d4s 66440 xnl). so far im happy with them. i also have diode dynamics max fogs
thanks to gxbobs videos, removing the bumper and headlights is not hard just time consuming....removing the ballast however was a pain. do them one at a time and ensure theyre at the same level before starting the other. i ended up reinserting the hid motor wrong causing the beam to point upwards.
Old 02-22-23, 02:06 PM
  #123
SAMT
8th Gear
SAMT's Avatar
Problem solved. Replacing a ballast on a car with AFS requires pulling or loosening the lateral position motor to fish the cable connecting the ballast to the bulb. When I initially put things back together with the new ballast and bulb, I failed to notice that the projector's framework was not engaged with the position motor. The projector had fallen forward so that the focus was way too high. I pulled the housings again and paid careful attention to aligning the projector axis and engage the position motor before tightening everything up. It worked perfectly, everything is excellent and I could not be happier.
Acrad (02-22-23)
Whitigir
RX - 3rd Gen (2010-2015)
13
03-05-14 01:51 PM
archangels
RX - 1st Gen (1999-2003)
05-07-08 04:17 AM
DrewGS4
07-18-02 06:42 AM
skfds
IS - 1st Gen (2001-2005)
03-26-02 12:06 PM
Quick Reply: 2010-2013 AFS HID headlight adjustments,conversions,component replacements
