Engine Thermal Expansion or Clicking/Knocking/Pinging
Old 05-19-19, 01:09 PM
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Received 3,669 Likes on 2,401 Posts
Actually that fan is the belt driven cooling fan on the radiator. The emission air pump fan only runs during cold starts.
Here are some of tecman's pictures of it. This is under that cover over the radiator but in pics notice the windshield washer fluid fill for orientation
https://www.clublexus.com/forums/gx-...ml#post9903088
Acrad is offline
Old 05-19-19, 01:17 PM
nastron
nastron's Avatar
Ah, that makes sense, thanks for the info!
Can you usually hear it from the inside on a cold start?
nastron is offline
Old 05-19-19, 01:19 PM
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Only if I turn off everything and explicitly listen for it.
Acrad is offline
nastron (05-19-19)
Old 05-19-19, 01:24 PM
nastron
nastron's Avatar
Gotcha. I'm kinda more convinced now that it's probably not a problem and all I'm hearing is probably thermal expansion or something, especially since this system throws a code or even more if any kind of failure occurs with it. I'm just being **** with this since my previous 2012 RX 350 had me at the dealership most of my weekends during the last 2 or 3 months of ownership.
nastron is offline
Acrad (05-19-19)
Old 05-19-19, 01:26 PM
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
I hear ya... I get the same way about things like that.
Acrad is offline
nastron (05-19-19)
Old 05-19-19, 01:36 PM
nastron
nastron's Avatar
I'll try to reproduce with another GX next time I'm at the dealership for my next service. That'll put my mind at east if I hear the same clicking noise .
nastron is offline
Old 05-19-19, 02:10 PM
nastron
nastron's Avatar
Check this out Acrad35751, I was just double checking the noise outside in my garage and I noticed this other strange noise that I think is coming from that same air pump when I shut off the engine:
That's definitely not normal right?
nastron is offline
Old 05-19-19, 02:18 PM
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Let me look around some. I thought they changed the logic on '14+ to possibly have a shutdown cycle with the air pump.
Any other '14+ owners hear this on shutdown?
The Hewitt-Tech owner user (HewittTech) might be able to chime in as well.
Acrad is offline
nastron (05-19-19)
Old 05-19-19, 05:00 PM
HewittTech
HewittTech's Avatar
The sound you are hearing when you start it up sounds more like an exhaust tick to me. Really hard to tell without hearing it in person.
On startup the secondary air pump is more like a whine, runs 30 second to a minute and and then you may the air switching valves close and the whine go away. On some vehicles it is more noticeable than others. For instance, you typically don't hear the pumps run on the 5.7l or 4.7l unless they are failing because they are isolated under the intake or inside the passenger front fender. The 4.0 and 4.6l usually have the pump just under the hood so they are more noticeable.
The noise you are hearing on shutdown in the clip is absolutely the secondary air system. As far as i am aware all 2015 and newer vehicles will run the air pump at shutdown. All 2013 and newer 4.0l run at shutdown. There is a possibility with a certain reflash certain 2012 and 2013 5.7l can but most don't but all flex fuel 5.7l vehicles do.
The system running at shutdown is why our current V3 and V5 units only half work on those vehicles. On those vehicles that run the system at shutdown they still stop the system from running on startup but can't prevent it from running at shutdown. This is where our soon to be released Second Generation bypass kits will take over and cover up to the current model year. Instead of just preventing the system from running we essentially simulate it so the computer thinks everything is functioning as it should. This also eliminates the need to keep most of the system on the vehicle.
We are trying hard to get our production caught up and able to produce the new units as well. We manufacture everything in house so it takes a little longer but we hope to have the Next Gen units available this summer, summer 2019.
Please contact us directly by email or phone for more information or inquiries about our current or next gen bypass kits for the secondary air system on these vehicles.
HewittTech is offline
The following 3 users liked this post by HewittTech:
Acrad (05-19-19), nastron (05-20-19), tecman (05-19-19)
Old 05-19-19, 05:21 PM
tecman
tecman's Avatar
Why did Lexus have this system run on shutdown starting with 2015 with the well known history here? What is the reason for this?
tecman is offline
Old 05-19-19, 06:06 PM
HewittTech
HewittTech's Avatar
It is to help prevent failures and is essentially the third iteration/improvement of the system.
I think it is to blow any residual moisture out of the system. This prevents water collecting in the pump that can damage the vanes and the valves from freezing closed with ice. They also added a pump heater to the system to drive moisture out of the pump motor. Will it help? Time will tell.
The following 2 users liked this post by HewittTech:
Old 05-19-19, 06:13 PM
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Do you know if the 10-13 models which are fixed under the warranty extension get this version of air pump with heater?
Acrad is offline
Old 05-20-19, 05:08 AM
HewittTech
HewittTech's Avatar
They would not. The air pump heater is not added until 2014.
Acrad (05-20-19), nastron (05-20-19), tecman (05-20-19)
Old 05-20-19, 06:50 AM
nastron
nastron's Avatar
Thumbs up
Thanks for the information HewittTech! It's great to hear about the soon-to-be-available second gen bypass kit!
nastron is offline
Old 05-20-19, 07:15 PM
John00
John00's Avatar
my 2012 does the shut down pump thing ever since i got the pump changed and box flashed. they did say it was to get moisture out in an attempt to not have more issues. they also told me that none that have had this fix have had to come back. i spose i should add 'yet'.
John00 is offline
Quick Reply: Engine Thermal Expansion or Clicking/Knocking/Pinging
