Oil Consumption
Oil Consumption
I recently purchased a new 2019 GX. I'm planning a lengthy road trip soon. Do I need to keep an eye on oil level? What are the oil consumption characteristics of this engine?
i have a 14 and have not noticed any oil consumption between changes. However, depending on how many miles you have on it, I might do an oil change prior to your long trip.
I always change oil at 1,000 miles on a new car to purge the break-in particulates. Yes, the oil filter captures most ... but ...
Side note on break in procedures:
-Vary RPM and avoid cruise if you can.
-Depends on your personal beliefs, but a 1k oil change is usually a good preventive thing. Factory fill isnt a special break in oil so no probs there as well.
Super Moderator
I've only got 55K miles but no hint of oil consumption. I haven't measured drain amounts but solidly on the full line after 4-5K miles. For what it is worth...IMO: I really don't expect internal consumption issues to be a problem on this engine.
Follow what Lexus recommends. Doing anything more is just a waste of $$$$. But that is your call because it is your wallet.
If you don’t want to listen to Lexus, then these are valid points in this article: https://www.edmunds.com/car-maintena...motor-oil.html
Or Consumer Reports: https://www.consumerreports.org/car-...-for-your-car/
But, boringly, CR recommends......following your Owner’s Manual or your car computer.
Or here where VW dealer recommends 10k miles changes, even your 1st one: https://www.charlottevw.com/first-oi...rlotte-fl.html
Quick summary of everything above...3k oil changes is a waste of money in a modern car. You do NOT have to change before a long trip UNLESS your normal oil change interval falls within that trip. You do NOT have to change oil within first 1k miles...no facts at all from major manufacturers to back this claim up. Your car computer (and/or owner’s manual) is smarter than the internet. Trust it.
Just bought a 2019 Gx460 ... Lexus says first oil change at 10,000 miles. Lexus dealership says 5,000 miles ... Hmmmm
My vehicles are long-term ... so I use judgement based on what I have seen as a Certified Master Mechanic versus trusting that any auto manufacturer recommendation favors my interest beyond their warranty vested interest.
Lexus vehicles typically dont have a Oil Life monitor, only a maintenance reminder which is reset after each oil change; Lexus has yet to implement a system similar to what other makers use in their vehicles which takes into count duty cycles, engine load and rpm, and other information it can assess.
Everyone has a vested interest. Quickie-Lube businesses say 3,000 miles to drive sales. Manufacturers say 10,000 miles given their interest ends when the warranty period ends ... combined with wanting to be up-front sales competitive by representing "low(er) maintenance" when compared to the competition.
Not sure about your dealership, but my dealership recommends tire rotations and inspection every 5k...but oil change every 10k.
You’re a Certified Master Mechanic? And you did not know about unsprung weight?
You know as a new owner of a 2019 GX I find this absurd. I have a 2001 Chevrolet base Tahoe that I bought new in the year 2000 and it measures cold starts, distance, etc to determine oil change intervals. Good grief --Toyota's premier line is not up to Chevrolet technology from almost 20 years ago?!
