Serpentine/V-belt replacement
Old 01-30-19, 11:40 AM
bbqsoup
bbqsoup's Avatar
The belt fit many vehicles so maybe one the diagram is for a Sequoia or Tundra?
The part I got is 90916-A2023
https://www.toyotapartsdeal.com/oem/...916-a2023.html
Old 01-30-19, 11:43 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,553 Likes on 2,327 Posts
IIRC there is a sticker under hood showing belt pattern as well
The following 2 users liked this post by Acrad:
bbqsoup (01-30-19), tristero (03-17-19)
Old 01-30-19, 11:52 AM
tecman
tecman's Avatar
I forgot about the sticker.
Old 03-15-19, 01:07 PM
Romanova
Romanova's Avatar
Ordering mine to give it a go next week or so. Even though it's tight, it looks doable without too much fuss. Will document it with pictures and tips once it's complete.
My belt looks fine at 117k, no cracks at all, but with all of my documentation, I show no history of it being replaced.
FYI, OEM belt is about $90. Half tempted to run a Conitech or Dayco which is less than $30.
Acrad (03-15-19)
Old 03-15-19, 01:14 PM
bbqsoup
bbqsoup's Avatar
If OEM belt lasts 117k miles I'd would swing another $30 and go OEM again. One thing I don't cheap out is brakes and belts
Old 03-15-19, 01:19 PM
JonGX
JonGX's Avatar
Does anyone have any idea who the OEM supplier is for the belts? I’ve run contitech belts in bmws for a long time with no issues
Old 03-15-19, 01:30 PM
Romanova
Romanova's Avatar
It'd be an extra $60 for OEM. Even if I have to replace a cheaper one sooner, I'd still come out ahead and since we only drive it about 8k a year or so, I'm going to try the Continental. I'm a huge proponent of OEM parts but just not in this instance.
RSimz (06-09-22)
Old 03-15-19, 01:31 PM
Acrad
Super Moderator
Acrad's Avatar
Nothing conclusive but I've seen many say that Toyota/Lexus OEM belts are made by ----> Gates or Bando
Old 03-15-19, 01:42 PM
bbqsoup
bbqsoup's Avatar
I wished I kept my old belt but I remembered looking at it and couldn't find any references to who made it. I used Gates belt on other cars and they are good. I'd go with Gates if going aftermarket. It's only $42 so not that bad.
Probably not needed, but it may be also a good idea to replace the tensioner too.
Old 03-15-19, 01:44 PM
Acrad
Super Moderator
Acrad's Avatar
I will probably throw a new belt on mine in 5/2022 when rig is 10 years old. I just don't think I will reach the mileage before then since I am only at 55K miles and doing around 10K miles a year.
Old 03-15-19, 02:03 PM
Romanova
Romanova's Avatar
Ordered the Contitech. Will reuse the tensioner and idler pulley as they should still be fine at this mileage.
Old 03-15-19, 10:46 PM
ROSCOGX470
ROSCOGX470's Avatar
i checked my belt on my 2011 with 74k and it looks good, however on damp days at first start up it does squeal for A minute or so. Could be normal or first signs of stretching belt.
Old 03-16-19, 02:30 PM
Acrad
Super Moderator
Acrad's Avatar
5.7L...but surely applies to 4.6L....just a tip in releasing tension on belt. (time: 0:50)
John00 (03-17-19), Romanova (03-17-19)
Old 03-17-19, 07:52 AM
Romanova
Romanova's Avatar
https://youtu.be/52MAer_7-QA?t=53
Yeah I saw someone posted that on the GXOR group... good stuff!
Old 03-17-19, 10:38 PM
tridizzle
tridizzle's Avatar
No need to remove the fan or anything but the covers on the bottom. All you need to do is pull on the tensioner (6*) and the belt will loosen up. When putting it back on, snake the belt up and above the fan first and pretty much everything else will fall into place, and I found it installing it from the bottom is much easier. When putting it back on, let the last loop be the tensioner that you're pulling on due to it'll be easier to sit the belt on the smooth surface rather than the pulleys with grooves in them. I've replaced my own, took about 20 minutes. Very simple!
The following 2 users liked this post by tridizzle:
Acrad (03-18-19), Romanova (03-22-19)
Quick Reply: Serpentine/V-belt replacement
