4-Low noise in newly acquired 460
Old 10-17-18, 09:57 PM
jojotheduc
jojotheduc's Avatar
Default 4-Low noise in newly acquired 460
Just bought a used 2015 460 with ~30K miles and, like an idiot, I forgot to test 4L during the test drive. Last night, on pavement, I switched to 4L and the transfer case made an awful loud grinding noise. It did switch over though and I was able to drive a bit. When I switched back it made the same noise. Anyone experience something like this? Is there some maintenance I can do to address, or is it likely that the transfer case is near shot? Since I was on pavement, I left the diff alone.
jojotheduc is offline
Old 10-18-18, 03:14 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,561 Likes on 2,331 Posts
Were you at a complete stop and in neutral?
Mine will either make no noise or just a slight short engagement noise.
It may have never been engaged before. Your vehicle is still under the 6/70 powertrain warranty so if there is an issue Lexus will fix it for free.
Acrad is offline
Old 10-18-18, 04:25 AM
jojotheduc
jojotheduc's Avatar
I was at a stop and in neutral, but I only waited about a second to switch it over. I'm reading some 470 owners suggest waiting 3-4 seconds. To be safe I'm going to have the transfer case inspected. I needed to bring it in for a sun visor replacement anyway.
Old 10-18-18, 02:38 PM
Acrad
Super Moderator
Acrad's Avatar
I always try to give mine 5 seconds to complete.
Acrad is offline
Old 10-18-18, 04:16 PM
jojotheduc
jojotheduc's Avatar
Tried it again today. Gave it a solid five seconds and it switched over with a gentle click. Now to add crawl and MTS!
Acrad (10-18-18)
Old 10-18-18, 05:04 PM
tecman
tecman's Avatar
Ashamed to say I have never fully tested my GX. I did use 4low when we had a bad ice and snow storm here in Georgia years ago. I am afraid that I might be asking for trouble if I fully test this and I have no need so far. I am interested if it is in good working order but a bit freaked out to test it. I would have to search for off-road muddy terrain where I live to be comfortable with testing 4low and locked diff. Meh, street tires and wheels on my GX.....
Amateur off-roading post here
tecman is offline
Old 10-18-18, 06:23 PM
Carnevino
Carnevino's Avatar
Always do this on gravel or dirt rather than asphalt. There’s a thread regarding this somewhere on here. I engage mine once a month now.
Carnevino is offline
Old 10-19-18, 08:37 AM
KJ6IRM
KJ6IRM's Avatar
There's no issue engaging 4lo on pavement with a GX460. You can do this and drive around in circles all you want, it's not going to do any damage. You should however only engage the center differential lock on a loose surface, be it in 4hi or 4lo.
KJ6IRM is offline
Carnevino (10-19-18)
Old 10-19-18, 08:39 AM
KJ6IRM
KJ6IRM's Avatar
No need to have it inspected for that noise. That's normal if you didn't give it time to engage (see below). I would however have fluids changed in the transfer case and both differentials if they haven't been done in a while.
You just need to wait for the 4lo light on your dash to stop flashing and turn solid. Sometimes it faster than others.
Similar to engaging the transfer case, wait until the 4lo light stops flashing and goes out before putting the transmission back into gear.
KJ6IRM is offline
Old 10-19-18, 12:50 PM
Acrad
Super Moderator
Acrad's Avatar
I love that you can drive this rig in 4L with an open center diff on pavement. First vehicle I have had that can do that.
Acrad is offline
USCRugby
03-10-24 04:59 PM
Kostyan
RX - 3rd Gen (2010-2015)
04-01-17 02:17 PM
RXGS
04-18-15 07:57 PM
nx200tmb
NX - 1st Gen (2015-2021)
01-18-15 12:10 PM
EnzoRX
RX - 1st Gen (1999-2003)
12-27-02 04:31 AM
Quick Reply: 4-Low noise in newly acquired 460
