Curt 13043 Install Help
Old 06-11-18, 02:50 PM
Surfishing
Surfishing's Avatar
Default Curt 13043 Install Help
I ordered the Curt 13043 hitch and plan on towing a 6x8 trailer fairly often with me 2011GX with oem airbags. I test fit the hitch but have some questions for those that have this installed.
The instructions don't address the following two questions I have:
1. Should the conical tooth side of the washer face the base of the hitch or the head of the bolt?
2. Some folks have reported using washers on the bolt to get the hitch to fit. Curt provided me with a plate to remedy this issue. Has anyone else installed the hitch using this plate? I'm concerned the length of the bolts may not be sufficient (specifically sheering the bolts).
Thanks!
Surfishing is offline
Old 06-11-18, 11:08 PM
omgitsroy
omgitsroy's Avatar
From the photos it’s hard to see how much thread you have left after installation, but if you have two threads left/extra then you have enagaged the entire strength of the bolt. Alternately meeting torque spec should get you the recomeened rated capacity.
omgitsroy is offline
Old 06-12-18, 09:05 AM
oubobcat
oubobcat's Avatar
I had this issue with my curt hitch, and I had them make the shim you have and send it to me. THis was about 2 yrs ago.
Try searching on my name for the bolt size, but you do need a longer bolt. I have a post with the size listed, I got them from NAPA for a dollar each I think.
oubobcat is offline
Old 06-12-18, 01:35 PM
bbqsoup
bbqsoup's Avatar
I wonder why Curt has this issue while a cheapo one I got from ebay fit fine. Design or it was retro
from another mode?
bbqsoup is offline
Old 06-12-18, 02:54 PM
tipsytopsy
tipsytopsy's Avatar
from another mode?
It fit just fine on my 2018.
tipsytopsy is offline
Old 06-14-18, 06:47 PM
matts17
matts17's Avatar
I don’t think you need that shim on the pre 2014 model. I could certainly use that on my 2017 and my Curt hitch did not come with that. My hitch rubs on the lower bumper trim and has removed dabs of paint. Maybe I should call Curt??
matts17 is offline
Old 06-15-18, 05:35 AM
T4Fun
T4Fun's Avatar
mine didnt come with shim either but that was few years ago. Bolts have to be torqued to like 85 or something
Amazon Amazon
T4Fun is offline
Old 06-15-18, 09:07 AM
Surfishing
Surfishing's Avatar
Update:
The spacer was not needed. Matts17, let me know if you want mine, I'll be happy to part with it for free.
I bolted the hitch up with the conical tooth side of the washer facing the hitch.
I torqued to 86lbs-ft, per the instructions.
Old 06-18-18, 05:48 AM
regis2
regis2's Avatar
Didn’t get the shim with mine and it fits well on 2012.
regis2 is offline
Old 06-18-18, 08:41 AM
matts17
matts17's Avatar
Originally Posted by Surfishing
Update:
Thanks so much for the offer! I called Curt based upon oubobcat's post and they are sending me one. Thanks again though.
matts17 is offline
Old 06-18-18, 07:48 PM
ktranne9
ktranne9's Avatar
Surfishing, do you still have the spacer? If yes, I am interested. Thank you.
ktranne9 is offline
97JZA80
GX - 1st Gen (2004-2009)
23
04-11-21 08:18 AM
nx200tsas
NX - 1st Gen (2015-2021)
05-19-15 09:39 AM
memphisto
06-07-14 08:26 PM
z0lt3c
18
06-23-12 10:30 PM
bizzy928
05-26-07 02:27 PM
Quick Reply: Curt 13043 Install Help
