Front camera and Beat Sonic interface installation experiences
Thanks for the detailed write hzhao! I'm currently installing the harness on my vehicle and wanted to ask you where you used a power wire for the camera hook up? thank you in advance!
Super Moderator
I wish this was a '10-'13 option or I had already gotten front stock camera to work. It might have saved my front bumper last weekend. If nothing else I might install some kind of aftermarket camera system I can at least temporarily plug in when off-road.
Your welcome. I learned a lot from members on this forum and credits goes to everyone who contributed from various mods experiences. There is a topic discussed mainly on adding power outlet to the second row and had lots of suggestions on routing the power source. Just do a search and you should be easy to find them.
Here is a more in depth discussion on finding power sources: https://www.clublexus.com/forums/gx-...-gx-460-a.html
Super Moderator
+1... this is indeed a valuable forum and I too appreciate the participation, knowledge, feedback and overall collaboration we have here among us all
Do you have link to purchase the red wire with the fuse adapter end?
Amazon carries the “add a fuse” or “add a circuit”. The GX uses a low profile mini fuse. Be sure to purchase the correct style.
The fuse needs to be installed a certain way. New fuse for your new source goes on top. Original fuse is closer to the bottom prongs.
Also make sure the 12v power Is going the correct direction. Google image search “add a fuse install” there are some pictures showing the correct way. It’s a lot easier visually than explaining via text
Hzhao,
Was there an option to have the front camera come on automatically? Their website says under 9mph and the front camera activates similar to the stock LX.
For off roading, with my LX, camera will turn on automatically when MTS or Crawl Control is selected with guide lines. That is very nice and useful.
