Lexus All Weather Floor LINERS
Old 02-19-18, 04:29 PM
  #31
tecman
tecman's Avatar
Originally Posted by tincankill
Does anyone know if the floor retention clips from 2016-2018 GX's fit in the carpet holes on the 2013? I'd need one for each side.
This changed on the 2014 model. Last post shows it is doable.
https://www.clublexus.com/forums/gx-...-a-2010-a.html
Old 02-19-18, 09:00 PM
  #32
bbqsoup
bbqsoup's Avatar
My ‘10 didn’t come with any clips so when I got Weather Tech mats, I bought these clips. They fit perfectly.
https://rover.ebay.com/rover/0/0/0?m...2F321887570097
Old 02-20-18, 04:25 AM
  #33
FLGX460
FLGX460's Avatar
Confirming that I ordered the LINERS (part PT908-60170-04) for my 2013 GX 460 for about $115. The color matching is perfect and the rubber is very supple. Really a top notch product, although I would like it to extend up higher, esp next to the gas peddle. That area will definitely get soiled with a dirty shoe.
However, the fit is NOT perfect in a 2013 and there's a mismatch in two areas:
1) The edge of the liner next to the seat is a slight mismatch with the floor construction, but not a huge problem.
2) the holes in the liners DO NOT ALIGN with both of the hook clips in the carpet of the 2013 GX. On the 2013, the clips located on the outside of the vehicle on the driver and the passenger sides successfully line up with the liner holes. However, the clips on the inside of the vehicle do not line up - only the holes do. so you'll need to remove the clips. Here's what I did: used a dull knife to pry up the retainer pin, then pulled up and back on the far end of the hook clip, while holding the carpet down. Pulling up and back, it levers up and pops out without much problem.
Do you mind sharing where you ordered from, I ordered but it was cancelled because they didn't know the back order time. Also what's your interior color?
Old 08-23-18, 05:41 AM
  #34
jdelong
3rd Gear
jdelong's Avatar
hi all, new owner of 2013 GX 460 and trying to figure out what all weather mats to go with. There seems to be an abundance of 2014-2018 available in sepia (which is what I want). Is it a safe conclusion that they fit, but will require removal of the internal clips?
Thanks!
Old 11-09-18, 12:40 PM
  #35
jeepwm69
jeepwm69's Avatar
Wife just got a new 19 GX460 with "sepia" interior.
Going to get some either all weather floormats or liners for the front, and a mat for the rear.
Is the "dark brown" at match for Sepia? Nobody shows parts for a 19 yet, and the 18 parts show "dark brown" on most descriptions.
Old 11-09-18, 12:46 PM
  #36
GoHuskers
GoHuskers's Avatar
mine is Sepia and I think it matched well. See post #1
jeepwm69 (11-09-18)
Old 11-09-18, 01:19 PM
  #37
jdelong
3rd Gear
jdelong's Avatar
I ordered a set for my 2013, will report back on how they work
Old 11-28-18, 08:29 PM
  #38
DBLex1
DBLex1's Avatar
Does anybody know/have the different part numbers for the different colors of the liners?
i have a 15 with black interior and want to upgrade to the liners but I want to make sure I have the right part number before I order.
Old 11-28-18, 08:32 PM
  #39
DBLex1
DBLex1's Avatar
Update: I searched the mylexus site and it looks like there are two part numbers but no info on which ones are the black ones...
PT908-60170-04
PT908-60170-02
Old 11-29-18, 03:04 AM
  #40
Acrad
Super Moderator
Acrad's Avatar
Received 3,559 Likes on 2,330 Posts
[Sepia] - PT908-60170-04
[Black] - PT908-60170-02
Old 11-29-18, 10:24 AM
  #41
konc3pt
konc3pt's Avatar
Location: From Oakland to Sactown, the Bay Area & backdown
Anyone try the "luxurious" type or alike and can recommend a set ?
Old 11-30-18, 03:51 PM
  #42
DBLex1
DBLex1's Avatar
Originally Posted by Acrad35751
Thanks Acrad!
Old 12-13-18, 02:42 PM
  #43
RoadDawg
RoadDawg's Avatar
One tiny part of me looks at these and sez, "Cool." The other, larger, non boy racer part looks and sez, "Vulgar." Always a trade-off, I suppose.
Old 12-13-18, 02:45 PM
  #44
Acrad
Super Moderator
Acrad's Avatar
Somehow I think I would have to stock up on these if I had those :-)
SteveInCal (12-18-18)
Old 12-13-18, 08:50 PM
  #45
msgs350
msgs350's Avatar
I agree, those look gaudy and slippery. Would need to get the laminate "hardwood" trunk to match that "VIP" style.
Quick Reply: Lexus All Weather Floor LINERS
