Rear Door Table Mod
Old 06-24-18, 02:52 PM
  #61
Acrad
Super Moderator
Acrad's Avatar
Received 3,561 Likes on 2,331 Posts
It will definitely set off the alarm if fully locked but think I see what I need to do.
Old 11-03-18, 05:11 PM
  #62
msgs350
msgs350's Avatar
Originally Posted by Acrad35751
Pleasure meeting you today. Enjoy the KAON. If you do go with bolts into door frame like leftyguns post back. I may follow you. At that point I could service my Honda EU2000is on that table if I went with bolts into the sheetmetal. :-)
I'm finally taking this on today and went with nuts and bolts instead of the self tap screws as i feel it will eventually wear out the plastic and fail. I will post pics when i'm done..taking longer than expected as i needed to make a hardware store run due to some caps that i wanted to be fancy about and then the wife took the car to the grocery store... can't blame her, its her car after all.
Old 11-03-18, 05:32 PM
  #63
Acrad
Super Moderator
Acrad's Avatar
msgs350: Since you may have the rear door plastics off can you see if this yellow button in this post is an emergency release?
https://www.clublexus.com/forums/gx-...l#post10338564
[Removal]
https://www.clublexus.com/forums/gx-...l-removal.html
In addition... can you see if there is anything on lock mechanism that can actuate a rear door release? There may not be anything... or will likely set the alarm off. Thinking about using a electronic servo or solenoid with a switch to actuate a rear door release from the inside.
A lot to ask but greatly appreciated if you have time. :-) No worries if you don't have time.
Thanks!
Old 11-03-18, 05:38 PM
  #64
msgs350
msgs350's Avatar
[Removal]
Thanks!
Sure, i will have a look later..I will text you when the I resume this later for any details. Happy to get you any info you need since you're a great resource of info for us here.
Acrad (11-03-18)
Old 11-03-18, 06:57 PM
  #65
msgs350
msgs350's Avatar
Finally installed mine since I picked it
up from Acrad35751 a few months back. Install was pretty straight forward (panel removal tools are a must in my opinion) with the info collected from this thread. I opted to use nuts and bolts to mount this rather than the self tapping screws that came with the table. For a cleaner look, I also opted to get covers similar to what you would use for liscense plates for my install.
The following 3 users liked this post by msgs350:
Acrad (11-18-19), bbqsoup (11-04-19), ltsr (11-07-19)
Old 05-05-19, 05:26 AM
  #66
oksir83
oksir83's Avatar
I saw that OrangeBoxxFab will be releasing a drop down table for the 460 soon. However, the similar table for the 470 runs $400+, so I would imagine a similar price, although they have more features w/ the molle panel.
With that being said, I went ahead and ordered a Kaon table from Australia. After conversion and shipping, it was right at $260. I have a toddler and feel like I always need an extra place to set stuff, so this should be a perfect solution.
Acrad (05-05-19)
Old 11-18-19, 02:26 PM
  #67
bbqsoup
bbqsoup's Avatar
I’m now a new member of the Kaon club.
Thanks for @ltsr for coordinating the purchase. Install was straightforward and I just screw it into the back plastic panel for now. Will eventually take it out and use the bolts at a later time.
Hope to put it to many uses in the future.
Add some pics
Attached Thumbnails Rear Door Table Mod-img_6381.jpg   Rear Door Table Mod-img_6382.jpg   Rear Door Table Mod-img_6383.jpg
The following 3 users liked this post by bbqsoup:
Acrad (11-18-19), ltsr (11-18-19), nuclearn8 (11-18-19)
Old 11-18-19, 02:53 PM
  #68
ltsr
ltsr's Avatar
It looks like @bbqsoup and I got newer/different hardware than previous Kaon folks. Got hex head self tapping bolts instead of Philips head. They also included a rubber lining on the tray itself where it meets the gate plastic when closed.
Old 11-18-19, 03:01 PM
  #69
Acrad
Super Moderator
Acrad's Avatar
It appears the latch setup is different with the straps as well. Nice upgrades!!!
Old 11-18-19, 03:07 PM
  #70
bbqsoup
bbqsoup's Avatar
When I saw the self tapping hex, I was like, my power tool will strip the rubber panel LOL. So I ended up drill a small hole and use a ratchet.
Old 11-18-19, 03:42 PM
  #71
Acrad
Super Moderator
Acrad's Avatar
So self tapping into the steel part of door? I need to get around to securing mine into metal part of door. It would increase my load capacity of table significantly.
bbqsoup (11-18-19)
Old 11-18-19, 05:24 PM
  #72
nuclearn8
nuclearn8's Avatar
I used the self tapping hex head screws for now too... will bolt it to the plastic panel when I take it off to do the soundproofing.
The following 2 users liked this post by nuclearn8:
bbqsoup (11-18-19), msgs350 (11-20-19)
Old 11-20-19, 10:57 AM
  #73
msgs350
msgs350's Avatar
I like the latching and the rubber strip on the updated version. Looks great!
Old 11-20-19, 02:38 PM
  #74
Acrad
Super Moderator
Acrad's Avatar
I had some of this in my supplies but this will work for that rubber strip piece.
This was a roll I bought in 2018.... not available here but this stuff is sold everywhere. I'm gonna put some on mine... never thought about it until I saw the updates on this updated KAON model.
Amazon Amazon
msgs350 (11-20-19)
Old 12-07-19, 08:12 AM
  #75
Acrad
Super Moderator
Acrad's Avatar
KAON sent me latch kits for the two tables I ordered for the new upgrades minus the rubber seal trim but I already have a spool of that.
I plan to install mine today.
msgs350: I will get yours into the mail on Monday.
The following 4 users liked this post by Acrad:
bbqsoup (12-07-19), ltsr (12-07-19), msgs350 (12-07-19), nuclearn8 (12-08-19)
Quick Reply: Rear Door Table Mod
