TPMS / TPWS Questions/Comments/Concerns
Old 12-13-17, 05:04 PM
  #106
Acrad
Super Moderator
Acrad's Avatar
Received 3,553 Likes on 2,327 Posts
Interesting about a potential OEM unit
Thought about reaching out to Carista developer who I think has posted here. I think there was some TPMS reset fuctionality in development and this could tap into this info as well.
Old 12-13-17, 05:36 PM
  #107
bbqsoup
bbqsoup's Avatar
I'm pinging a friend to get in touch with the seller of the device posted earlier in this thread
https://detail.tmall.com/item.htm?sp...=3668636543624
According to the seller, it is using 315Mhz and will work with Toyota/Lexus TPMS model 42607-33040. The GX uses 42607-33021. He's checking to see if it works with the GX model since he said same car model will use different protocol on the same frequency due to country restriction.
I also found that if you don't have tmps from manufacture, you can get after market tmps that will work wirelessly with another display.
Old 12-13-17, 07:34 PM
  #108
Dallasguy1
Dallasguy1's Avatar
I could get individual tire pressure on my GS also I think it's the upgraded cluster. While Lexus is using the same since 2010 not sure about the 2018 but seems like it's still the same and won't be showing u individual pressure.
Old 12-13-17, 07:40 PM
  #109
Acrad
Super Moderator
Acrad's Avatar
The sensors also give off temperature readings that you can see in Techstream.
Old 12-14-17, 01:38 AM
  #110
tqh
tqh's Avatar
Found it! This is the one I saw years ago, oem, has toyota logo and stuffs. I wonder it'll work with the GX?
http://lismoretoyota.com.au/new-toyo...cessories.html
"All the right pressure, with none of the stress. Dash-mounted, backlit, small and sophisticated, the system's display receives data wirelessly from sensors mounted inside each wheel. Temperature and pressure of all five tyres (including the spare wheel) are sequentially displayed in various measuring units. Advanced functions allow for wheel rotations and a variety of display models. There are even programmable alarms for low tyre pressure, tyre over-temperature and sensor battery replacement."
Acrad (12-14-17)
Old 12-14-17, 02:38 PM
  #111
Acrad
Super Moderator
Acrad's Avatar
Great Find!!! Very interested to see if this is still obtainable and compatible.
Old 12-14-17, 03:08 PM
  #112
Acrad
Super Moderator
Acrad's Avatar
This $250 unit would probably work as a general reader but we continue the search for something that can be mounted. :-)
https://www.ateq-tpms.com/en-us/prod...gramming-tool/
Knowing PSI at a glance is really practical knowledge. This would be a time saver as I check my pressure every week or so.
This looks like a decent unit for those swapping winter and summer tires and not using Techstream. No idea how well it works but around $130.
http://www.maxitpms.com/tpmscms/product/580.jhtml
Old 12-14-17, 03:56 PM
  #113
Acrad
Super Moderator
Acrad's Avatar
Looks like that unit may have been EOL'd at some point.
http://www.ebay.com.au/itm/Genuine-T...8AAOSwvv5ZeUX0
https://www.holmart.com.au/toyota-ta...itoring-system
Looks like PN: PZQ88-28010
Old 12-14-17, 06:28 PM
  #114
tqh
tqh's Avatar
I have a MaxiTPMS TS401 myself, got it used from ebay for $90. It is pretty decent, quick measure of the pressure and temp. But it can't beat a unit constantly updating the pressure while I sit comfortably inside the car :-)
Old 12-19-17, 03:52 PM
  #115
Acrad
Super Moderator
Acrad's Avatar
bbqsoup posted some links in this Auto Folding Mirror thread. Definitely following that one ...but this also caught my eye.
Not exactly what I was looking for since it doesn't show PSI but maybe more options on this site.
It claims to be OBD based as well.
Old 12-19-17, 04:08 PM
  #116
cicio
cicio's Avatar
There are hundreds of products like this. The way it works is that it gets data either from TPMS (if the car has one) or ABS data which I personally think is useless. The signal is the same as the OEM one. What this can do more is just to tell you which tire is punctured. I really do not think this function worth the money if you can just go out and take a look when the OEM light comes up. The auto-folding mirror looks interesting.
Old 12-19-17, 04:15 PM
  #117
Acrad
Super Moderator
Acrad's Avatar
Maybe 100's.... but still searching for something that will work with the OEM TPMS sensors and display actual PSI. If you come across one please post here. Everything else seems to require proprietary TPMS sensors.
Old 12-19-17, 04:24 PM
  #118
cicio
cicio's Avatar
The one I posted was the only one that might work with OEM sensor. Still waiting for more information from bbqsoup. I will probably assume there is no product like this if no one in the forum can find one or even the Chinese aren't making it.
Old 12-19-17, 04:25 PM
  #119
cicio
cicio's Avatar
Did you get any info from your friend if it will work on the GX with OEM sensors?
Old 12-19-17, 04:56 PM
  #120
bbqsoup
bbqsoup's Avatar
The seller said it works for the lexus in China but he's not sure if it will work for the GX 460 in the US due to potential different protocol being used.
cicio (12-19-17)
Quick Reply: TPMS / TPWS Questions/Comments/Concerns
