Performance Tuner - Throttle Response/Acceleration
Old 06-27-17, 02:04 AM
hilljack7
hilljack7's Avatar
Default Performance Tuner - Throttle Response/Acceleration
I am hoping to address the following 3 issues::
Throttle Response
Acceleration
Overall performance
I feel like there should be better throttle response/acceleration on my 2013 GX. I have never used a performance tuner and I'd prefer to keep it stock-ish. I know they are heavy trucks but I am unimpressed with this trucks ability to "get out of it's own way". I realize these are three separate issues but I am hoping someone can point towards some aftermarket product(s) to improve these areas. My searches didn't return anything very helpful.
Can anyone share if they've been successful using aftermarket tuner/throttle response products to wake these trucks up? Or maybe point me to a thread where this issue has been addressed?
Thanks
hilljack7 is offline
Old 06-27-17, 04:09 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,562 Likes on 2,332 Posts
Maybe look into Pedal Commander?
https://www.clublexus.com/forums/gx-...ml#post9847492
Acrad is offline
hilljack7 (06-27-17)
Old 06-27-17, 05:05 PM
jjscsix
jjscsix's Avatar
It's almost impossible to get any noticeable gains with just a tune on a normally aspirated engine.
jjscsix is offline
Old 06-27-17, 06:35 PM
Oldmanb777
Oldmanb777's Avatar
The overall performance is pretty much as expected. The car is pretty quick for its weight. Go back a few years, this quickness was reserved for performance cars. My dislike is the electronic throttle. If you had a cable direct to the throttle body (as it should be) you would get instant response. However an electronic servo, controlled by the computer, means, you are always going to be second guessed by the computer, as to what it thinks you want. So mash the throttle, instead of getting instant response, the computer decides what it thinks you should want, and gives you that. Bad over computerized, too much tech, over thinking your driving. Getting pretty much standard these days. Too much tech where it should not be.
Oldmanb777 is offline
Old 06-28-17, 05:53 PM
Acrad
Super Moderator
Acrad's Avatar
I am pleased with performance. I've seen several test claims online with 0-60 @ 6.8-6.9. It reminds me of acceleration just a tad slower than my old 2002 Maxima.
Acrad is offline
Old 07-02-17, 12:46 PM
Acrad
Super Moderator
Acrad's Avatar
I personally have no interest in adding this but shot off an inquiry to vendor to see what they say about 460 compatibility since the topic of performance mods often comes up.
JBA 2014S Header, Tundra 2010-2014 4.6L V8
http://urdusa.com/store/p1260519397/...duct_info.html
Probably not worth it for small gains though.
Acrad is offline
hilljack7 (07-04-17)
Old 07-02-17, 02:28 PM
Acrad
Super Moderator
Acrad's Avatar
Vendor got right back with me but wasn't sure about figment.
"Do not know. Are you close to us in Owings MD where you could come by and have a look?"
EDIT: Didn't realize the pre-cats are directly attached to the exhaust manifolds.
EDIT2: From vendor: "The exhaust ports would be the same and it would bolt up there. Not sure about the air injection port.
You would have to cut the flange off of the back of the new header and weld your cat on to it."
Acrad is offline
Helogadget
09-04-17 09:44 PM
MjThind
IS F (2008-2014)
04-23-12 05:33 PM
lukeisf
IS F (2008-2014)
17
08-14-11 09:01 AM
jkeifer3
IS F (2008-2014)
04-01-10 09:35 AM
Suneet
12
06-07-07 11:33 PM
Quick Reply: Performance Tuner - Throttle Response/Acceleration
