View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 125. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#361
Now we knew the "070" is for sure will enable CC from 2010+ GX, which is a very good thing. Now we are waiting for actual confirmation on "040" for MTS from 2014+ GX. I will be get both done on my 2014 GX by the end of this month.
#362
Super Moderator
LexOverlnd (03-07-18)
#363
confirm part numbers
Mine's 15.
I used Techstream. It's a fairly simple process. Just follow the guide Acrad posted at #46.
This is what I did:
1. Enter the following menus: Chassis / ABS/VSC/TRAC / Utility
2. Reset memory
3. Test mode
(Both 2 & 3 are under the Utility menu)
DONE
This is what I did:
2. Reset memory
3. Test mode
DONE
Thanks,
#365
Done some reading lately, I have noticed, 050 and 051 are Drive Support Switch ECU only been used for oversea version of LC150 VX, and they were appeared for the model year 2008/09, and has never been associated with LEXUS GX, especially with 2nd generation of GX. So, we can safely assume, either 020 and 040 are the ones for GX if you are interested for MTS and other MTS associated functions such as multi-view cameras.
031 is just a replacement of 030.
#367
Super Moderator
This site claims a used 070 off a '12 in Birmingham, AL
https://autopartsfair.com/used-parts...xus_leads.html
No idea on price or availability.. this site makes you pay a little bit for leads or one could email all the salvage yards down there.
#368
Super Moderator
Another 020 option if Motor Heads option isn't available at some point but about $20-30 more ($171.19)
Unfortunately 040 doesn't show up in their database and 070 shows this but I emailed about it anyway.
https://en.impex-jp.com/
#369
Super Moderator
Internals of the stock 010 Driver Support Computer... just seeing if any internal numbers were relevant to find the supplier of this module to Toyota. Module opens up really easily.
#371
Super Moderator
I think you will be the first reported 040 install
#372
grrrrrrrr
UPDATE!!!!!!!!!!!!! ---> Re-read that website. That is a listing of PART REQUESTS and that one is MINE! (same date and time as my part request and yes, I DID "Qualify" myself as a buyer and paid the fee)
#374
Super Moderator
