Carista & GX
Super Moderator
Carista & GX
Anyone ever use Carista to make customizations on their GX? I know a lot of these seem to be available in the infotainment unit but some are not.
Personalization of comfort & convenience features of the car. This allows you to customize your car to your liking and get rid of all those annoyances you have to deal with every time you get into your car. You can even enable hidden features that you didn't even know your car had! See Pricing below.
Each particular car's supported settings can be different, but here's a sample list of settings from a user with a similar vehicle:
Lexus Gx460
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Beep when locking/unlocking with remote
YES / NO
Volume of beep when locking/unlocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Beep when opening/closing windows with remote
YES / NO
Warn (beep) when door can't be locked because it's still open
YES / NO
Panic function on remote
ENABLED / DISABLED
Open glass hatch via remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
ON / OFF
Lock doors when shifting into gear
ON / OFF
Unlock doors when shifting into park (P)
ON / OFF
Unlock all doors when driver's door is opened
ON / OFF
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Open glass hatch via smart key
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Instruments / Display / Dings:
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Remote low battery warning
ON / OFF
Front parking sensor range
NARROW / WIDE
Rear parking sensor range
NARROW / WIDE
Mute parking sensor when stationary for more than 3 sec.
YES / NO
Activate parking sensors in neutral (N)
YES / NO
Enable front parking sensors when in reverse (R)
FRONT / FRONT CORNER / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / OFF
Dash display mode
ALL / UNDISP
ECO Drive indicator zone
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Interior footlight (bright when doors open, dim when driving)
YES / NO
Center console spotlight (bright when doors open, dim when driving)
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on scuff plate light when smart key in range
YES / NO
Turn on scuff plate light when doors unlocked via remote
YES / NO
Turn on scuff plate light when driver's door is opened
YES / NO
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Heater & A/C:
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in "face" mode
YES / NO
Other:
Slide driver's seat back for easy exit
OFF / SHORT / STANDARD
Lexus Gx460
YES / NO
YES / NO
YES / NO
YES / NO
ENABLED / DISABLED
YES / NO
ON / OFF
ON / OFF
ON / OFF
ON / OFF
YES / NO
ON / OFF
ON / OFF
ON / OFF
ENABLED / DISABLED
ENABLED / DISABLED
ON / OFF
NARROW / WIDE
NARROW / WIDE
YES / NO
YES / NO
Dash display mode
ALL / UNDISP
ON / OFF
Lights:
ON / OFF
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
ENABLED / DISABLED
ENABLED / DISABLED
Heater & A/C:
YES / NO
YES / NO
YES / NO
YES / NO
Other:
I used it to disable the the seat belt warning (not available in the infotainment). My father occasionally rides with me and he never wears one. I don't wear it if I am just driving in my neighborhood.
Super Moderator
Good to know
Were you just using a run-of-the-mill OBD-2 BT or Wifi connector? I've got a drawer of them.
I had a splitter with a GPS tracker (personal use NOT insurance) and a WiFi. Problem is my phone would connect to it when I didn't want it to so I pulled it out. I don't use BT on my phone so that would have been a better choice for me to turn it on and off.
