Vibration/Shake Issues
#451
They can tell if the tire is out of round when Road Force balancing. I would take it back to the dealer. BTW, don't go with Bridgestone
tires, they're junk in my opinion. Had them on my 2014 at delivery and had them swapped out for Michelin LTX M/S2's
Was your vehicle under any warranty/certified when you purchased it? I would let the dealer take care of the problem.
Road Force is the only way to go, I have mine balanced at the dealer.
Good luck,
Craig
Good luck,
Craig
#452
Do you usually go to the dealer to do Road Force Balancing?
I've been using America Tires to balance all my tires for previous and current cars and they have been very good.
#453
The dealer is the only one I know who has a Road Force machine. I always have my dealer replace my tires as well. I don't trust some of the tire shops, they've damaged my wheels in the past. If you have a tire shop you trust and they have a Road Force machine, go with them. If the vehicle is under any kind of warranty, I would take it back where you purchased it from.
#454
I've never had my tires "road force balanced" in my life and have never had a problem with vibrations at freeway speeds without it.
Not saying there is zero value to it, but my guess is you have a tire shop that is not properly balancing your existing tires is why you are having issues. I have returned to a tire shop after they had just balanced my tires because I was having vibration issues and the next tech admitted the previous one didn't do it properly.
I have also had tires that internally had an issue that was causing a vibration problem that was resolved when it was replace. I believe it was an internal steel belt separating.
If the only way you can go down the road without vibrations is with a road force balance, I think you are simply masking the issue with a bandaid and not addressing the underlying problem.
Sad to say, but not everyone that works for a tire shop is a trained, valued employee that takes pride in their work.
#455
Sorry to get off topic. Craig B, you ordered a 2018 LC 500 Performance Package (in your signature) ...Nice, I love that car. Keeping the GX? Congrats
#456
Liquid Platinum/Black.
#457
#458
Super Moderator
Are we talking "Road Force Touch" or "Road Force Elite"?
#459
If you need road force balancing on a GX460, something is seriously wrong with the rim or tire. I still own my hunter tire changing equipment from my days of owning a tire store and I would never waste my time road force balancing a wheel on an SUV or truck. The only time I've seen it be a significant help, was when something was seriously out of round and even then, like someone said, it was just a band aid. And just FYI, a road force balance includes a high speed balance, the force just tells the operator where to place the tire on the rim. Once the tire is located to the rim, a high speed balance is done.
#460
Vibration at 68mph
Two weeks ago I posted about having tires road force balanced because I was getting a vibration at a higher speeds than 60mph. My first shot to solve it was to have the tires road force balanced. The guys at the tireshop they looked very good after I had them balanced so now I'm puzzled.
the vibration starts at 68mph and is consistent all the way to 80mph.
Now im thinking it could be a component in the car, I have the air ride (13' where only the rear rises and lowers) and it happens in all settings (comfort, sport or normal).
do you think it could be a drive shaft? What kind of movement would I look for when I'm moving it? On an old Land Rover just a little bit 2mm of movement caused a huge vibration but that was at all speeds.
All insight welcome. thanks
#461
Super Moderator
Might want to look through this thread...
https://www.clublexus.com/forums/gx-...gh-speeds.html
Might be your rotors.... I think there is a TSB as well related to steering rack but that only affected up the '12s IIRC
#463
I suspect a bad balance job this time as it is seat and stearing wheel vibrations. So frustrating
#464
Super Moderator
Do you know when the last time all the zerks were greased in the drivetrain? I thought I remember some posts on the 4Runner forums about driveshaft vibration related inadequately lubricated grease points.
#465
I don't. I can probably grease those myself and check for movement on the drive shaft. On the brakes there is no vibration at all when I break so I figure I can rule that out. All in all it feels very sensitive to minor nuances.
