Snow or Ice Driving Questions/Concerns/Experiences /Tires
Old 01-02-17, 03:27 PM
  #106
pinoyesv6
pinoyesv6's Avatar
Yea, you can't go wrong with either or. The blizzaks are great because they are a dedicated winter tire, but then the KO2s have mountain/snowflake symbol on them which means that they meet certain severe snow service requirements.
Personally I'd go with the GX. But in all honesty if the roads are really THAT bad, it might be safer at times to just pull over at a safe/warm place and wait things out. Much better than being stranded at the side of the road.
zbab31 (01-03-17)
Old 01-02-17, 04:23 PM
  #107
tecman
tecman's Avatar
Wider tires on the GX (correct?) and a heavier true truck to cut through the snow
Old 01-02-17, 04:32 PM
  #108
Htony
Htony's Avatar
Wider tires? No. Narrow tall tires cut thru snows. That is why winter tires are mounted on one size down rims. I live in snow/cold country. Tonight it'll be -25C, snow on the ground. If RX hybrid, shoud be in snow mode. No matter what drive for the road condition.
tqh (01-02-17)
Old 01-02-17, 04:56 PM
  #109
T4Fun
T4Fun's Avatar
true, thinner tires cut thru rain and snow and less likely to skid around.
But also when snow gets really deep, like up in alaska, they use big big tires to keep above snow.
tqh (01-02-17)
Old 01-02-17, 09:08 PM
  #110
bd5400
bd5400's Avatar
If the driving is on highways and interstates I'd take the RX with the snow tires. Snow tires are the most important factor when dealing with...snow.
With that said, I wouldn't be too worried about the GX either.
The following 2 users liked this post by bd5400:
QualityNut (09-13-19), zbab31 (01-03-17)
Old 01-02-17, 11:09 PM
  #111
Htony
Htony's Avatar
Summer tire rubber starts to harden at 7 deg. C. Hard rubber won't give good traction no matter how good the tire is. Winter tire rubber compound stays soft even if it gets cold. Get going with either tire is not much a problem but when stopping, sudden emergency maneuvers winter tire is always better in snow and cold weather.
Old 01-03-17, 06:33 AM
  #112
PapaLeo
PapaLeo's Avatar
BF KO2 has a snowflake icon embedded into a tire which means that it is considered winter tire.
Old 01-03-17, 06:49 AM
  #113
Quadro
Quadro's Avatar
It certainly is however just because two tires meet sever snow requirements doesn't mean one tire can't be better than another. The sever snow requirement is met when a tire can demonstrate 110 traction index compared to 100 index for some reference tire.
I think the only thing GX with KO2 will be better at is going through some really deep snow. When staying on a road and encountering slippery/icy conditions I would give preference to Blizzaks as it's a dedicated snow tire.I would not want to encounter black ice in a GX with KO2. Not that I want with Blizzaks either but with KO2 you will have no chance whatsoever.
Just look at the difference in siping (very important to deal with the slippery stuff) and it becomes pretty obvious which tire is superior. Plus Blizzaks will have a proper winter compound on top of it.
Old 01-03-17, 07:06 AM
  #114
PapaLeo
PapaLeo's Avatar
It's not just a tire that makes me recommend BF KO2. It's a car that they are mounted on.
Call me old-fashioned, but I trust GX with 4WD, Torsen diff, good old V8, and ability to start on the 2nd gear than a Hybrid RX with AWD (which is excellent car on its own).
Old 01-03-17, 07:10 AM
  #115
Quadro
Quadro's Avatar
4WD system in the GX is far superior no doubt about that. However if you just going to stay on a road the AWD system in the RX is going to be good enough. And stopping/cornering with Blizzaks will be far safer. Of course the ideal choice is GX with a true snow tire. Personally I would give RX + Blizzaks an edge just from a safety perspective.
Old 01-03-17, 10:10 AM
  #116
zbab31
zbab31's Avatar
Originally Posted by 11GX460
I'd go with the RX with the Blizzaks as those are dedicated snow tires. The only issue I can think of is the hybrid system in your vehicle. I used to own a 2010 Prius and it was horrible when I got stuck in the snow. Disabling the traction control system was not as simple as pressing a button, I had to perform a series of steps in order to disable it. Not sure if it's the same on your RX.
You also can't go wrong with the GX, but keep in mind the laws of physics when driving in snow, it's not the same as rain or dry pavement.
I know my RX has a snow mode so maybe it is the best choice?? but my husband mentioned the GX has rear lockers so that good but i dont know why?
Old 01-03-17, 10:12 AM
  #117
zbab31
zbab31's Avatar
Originally Posted by jtrue28
The GX is true 4WD. I would trust that more than the RX. Plus it has higher ground clearance. I think either way you should be fine though.
My theory is that 4WD is better when youre stuck, but maybe AWD with snow tires is better at high speeds? what do you think?
Old 01-03-17, 10:13 AM
  #118
zbab31
zbab31's Avatar
my hybrid is heavy too, not sure how they compare in weight in a side by side comparison
Old 01-03-17, 10:15 AM
  #119
zbab31
zbab31's Avatar
i feel like maybe we should have put snow tires on the GX and had a dedicated snow vehicle
Old 01-03-17, 10:17 AM
  #120
zbab31
zbab31's Avatar
i wonder if the rubber is soft and does well at low temps or if it is just a winter tire because of the depth of the tread? i have never in my life given this much thought about tires...the guy at the tire place was unsure too!
Quick Reply: Snow or Ice Driving Questions/Concerns/Experiences /Tires
