Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
Old 09-24-13, 06:17 AM
  #106
T4Fun
T4Fun's Avatar
Originally Posted by Koz
This stuff looks very interesting but I have been saved by never-seize (many times over many years) and would not even consider not using it on bolt threads. No matter how much time has passed (under any conditions, especially extreme heat) that bolt will break loose easily. I think this fluid film is more of a film protectant. I will get some and try it for many other applications that never-seize would not be practical!
Koz
FLUID FILM is incredible. i sprayed it under my whole gx after it was repainted from rust.
it keeps everything looking brand new and corrosion free.
Old 09-24-13, 06:54 AM
  #107
SecPole14
SecPole14's Avatar
Rust? What's the story behind this?
Old 09-24-13, 07:21 AM
  #108
T4Fun
T4Fun's Avatar
the rear axles on these rust like crazy, i didnt like it, so it got removed and repainted - happened after only 3K miles....i looked under other gxs and 4R's, and they all do it...
Old 09-24-13, 07:41 AM
  #109
SecPole14
SecPole14's Avatar
Ah, gotcha. So just typical SRA cosmetic rust. Happens on Mustangs too. Nothing for me to worry about.
Old 01-28-14, 05:40 PM
  #110
sgrol
sgrol's Avatar
Originally Posted by kroorda
You can get to the oil filter from up top on the GX.
I guess you would, at least, have to put a drain pan under the car to catch the oil draining from the filter housing.
Old 01-30-14, 04:40 AM
  #111
R3loader
R3loader's Avatar
How often are you guys changing oils. I noticed the GX has a 5000 mile interval while my Camry has a 10,000 mile interval.
Old 01-30-14, 06:13 AM
  #112
Eppieguy
Eppieguy's Avatar
The GX first oil change is 5K, then 10K and every 10k thereafter.
Old 01-30-14, 08:15 AM
  #113
Capirato
Capirato's Avatar
Originally Posted by Eppieguy
The GX first oil change is 5K, and every 10k thereafter.
Don't ask your dealer how often to change your oil, he'll say every 5k. They like for you to come in more often.
~ Cap
Old 01-30-14, 10:20 AM
  #114
JDSTL
JDSTL's Avatar
I don't know if all dealers actually change it at the first 5K but I'd pay to have it done. 10K is a lot on oil in a new engine.
From the maintenance schedule it says inspect and adjust at 5K and change at 10K:
6 Months or 5,000 Miles1
❑ Inspect and adjust all fluid levels ❑ Program Lexus Personalized Settings,
if requested ❑ Reset maintenance reminder light ❑ Rotate tires ❑ Visuallyinspectbrakepads,calipersandrotors ❑ Inspect wiper blades ❑ Check installation of driver’s floor mat ❑ Road-test vehicle
Note: If you drive primarily under certain special operating conditions, you should also replace the engine oil with 0W-20 oil and replace the oil filter. See page 44 for conditions that apply. Some conditions require additional maintenance. See below.
12 Months or 10,000 Miles2
❑ Replace engine oil with 0W-20 oil; replace oil filter
Old 01-30-14, 11:06 AM
  #115
Capirato
Capirato's Avatar
The first oil change is free.
~ Cap
Old 01-30-14, 11:20 AM
  #116
Eppieguy
Eppieguy's Avatar
Dealer changed mine for free at 5K, the rest have been out of pocket so I do it myself. I change it between 8k - 10k.
Old 01-30-14, 12:28 PM
  #117
JDSTL
JDSTL's Avatar
~ Cap
Right, but the maintenance schedule doesn't call for it until 10,000 miles.
Old 01-30-14, 01:30 PM
  #118
Capirato
Capirato's Avatar
I had them do the 10k Service at 5k for free, under Warranty.
~ Cap
Old 01-30-14, 01:33 PM
  #119
JDSTL
JDSTL's Avatar
~ Cap
Ahhhh, gotcha. Good thinking.
Old 01-30-14, 02:00 PM
  #120
Eppieguy
Eppieguy's Avatar
~ Cap
Same here.
Quick Reply: Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
