No audio or volume control. What's the problem?
UPDATE: ISSUE SOLVED, scroll down to see what the issue was.
2015 GX460 owner here. I installed the Beat-Sonic LGVIF-CB4W Carplay unit yesterday, and it worked for about a minute and then started cutting out. At first, I thought it was the wifi signal, but after connecting via USB, the problem continued. After another minute of wiggling wires trying to find the culprit, the audio cut out completely. I removed the Beat-Sonic device and reinstalled all the original wire harnesses to the stock configuration. After triple-checking everything, I still do not have audio. Here's the list of symptoms:
Questions for you guys:
UPDATE
I spoke with the service dept manager at Lexus today, and they recommended having one of their master technicians look at the issue. They said the fee to diagnose the problem would be $220, whether it took 8 minutes or 8 hours to pinpoint. I've got some micro needle probes coming for my multimeter today and will start trying to troubleshoot the issue myself before I go the Lexus route. If anyone has heard of this issue before, any help or tips would be greatly appreciated. Thanks, |
Since you mentioned there is no audio for any sources and no volume indicator, it seems there is no feed into the amp, and your head unit functioned OK. As you unplug and put inline BeatSonic unit, have you checked if the Audio connector, I believe it was an 8 or 10 pins white connector, that is feeding the pre-amp signals to amp, if that one has been damaged, such as broken pins?
Originally Posted by hzhao
(Post 11441899)
I'm really at a loss for what this could be. |
Originally Posted by 29er
(Post 11441944)
I've removed all the BeatSonic devices and cables, so everything is back to stock, and I still don't have audio. I checked all the cables and pinouts and they all look fine.
(Post 11441971)
In worst case, you may have a malfunction Amp unit. Did you check the fuse for the amp, also check under the passages seat, if amp is getting power or if it is working.
(Post 11441976)
It's the Mark Levinson system, so I believe the amp is in the back of the vehicle on the left, right? Unless there's another amp I'm not aware of.
Do you know how to use a multimeter?
Originally Posted by evilfij
(Post 11442206)
(Post 11442001)
You are correct if you have the ML system. Are all fuses OK? And Amp is powered up?
(Post 11442206)
I didn't get to use the multimeter today, but I did plug in my OBD2 scanner and got this DTC code: B15D0
This is what the error means: The MOST network cannot be established after the master unit is activated.
To make it even more interesting, the self-diagnostic test reports the MOST network is OK. https://cimg8.ibsrv.net/gimg/www.clu...77dbdbe317.jpg |
Yep, found that too.
Looks like me and my multimeter are gonna have some fun today. |
Is it a single line-out to the amp or is there one for each speaker? I’m thinking pinched/damaged wire given it was intermittently working initially. Sorry this happened, good luck!
| All times are GMT -7. The time now is 06:02 PM. |
