Is this GX a lemon?
Old Oct 25, 2019 | 01:04 AM
dwh13's Avatar
dwh13
Default Is this GX a lemon?
I'm in the market for a GX and have been searching for about 3 months now. I found a promising one (2012 base model in Grey) for a good price with 100k miles. I pulled the history on the Lexus website and found that it's had a lot of issues, but they've all been repaired at Lexus. Would this concern y'all, or should I take it as a sign that it has had every issue cared for?
10k miles -
SERVICE: RESEALED OIL PAN BOLT
DESCRIPTION: RESEALED OIL PAN BOLT ~|~LEAK AT OIL PAN BOLT ~|~POROUS ~|~10200 BOLT LEAKING OIL 111991 040 REMOVE BOLT TO CLEAN OIL RESEAL BOLT TK10411
20k miles -
SERVICE: FOUND COOLANT ENTRY INTO CYLINDER #7, HEADS WERE REMOVED AND RESURFACED, AND ENG
DESCRIPTION: FOUND COOLANT ENTRY INTO CYLINDER #7, HEADS WERE REMOVED AND RESURFACED, AND ENG ~|~CHECK ENGINE LIGHT IS ON AND FLASHES OFF AND ON. VEHICLE IS RIDING VERY ROUGH AND POOR ~|~ ~|~21365 2160 FOUND COOLANT ENTRY INTO CYLINDER #7, HEADS WERE REMOVED AND RESURFACED, AND ENGINE WAS REASSEMBLED. #7 PLUG MOVED TO CYLINDER#3. VEHICLE WAS TEST DRIVEN, AND HEALTH CHECK WAS PERFORMED TO CHECK FOR ANY CODES AFTER EXTENDED TEST DRIVE
SERVICE: TEAR DOWN OF ENGINE, AND SENDING OFF OF HEADS TO BE PRESSURE TESTED COMPLETED
DESCRIPTION: TEAR DOWN OF ENGINE, AND SENDING OFF OF HEADS TO BE PRESSURE TESTED COMPLETED ~|~TEAR DOWN LABOR TO DIAGNOSE INTERNAL ENGINE DAMAGE SUSTAINED ~|~ ~|~21318 2160 TEAR DOWN OF ENGINE, AND SENDING OFF OF HEADS TO BE PRESSURE TESTED COMPLETED
70k miles -
DESCRIPTION: LEXUS REPAIR ~|~C/S: TRANSFER CASE IS LEAKING CHECK FOR WARRANTY C OVERAGE ~|~POROUS, PINHOLE ~|~OP CODE-390991. 8.5HR. T1-65. T2-48 FPN- 90311-43008, 90311-43007. INSPECTED VEHICLE FOR TRANSFER CASE LEAK. FOUND OI L/GREASE LEAKING FROM TRANSFER CASE AND TRANMISSIO N SEALING SURFACE. REMOVED TRANSFER CASE AND FOUND LEAKING TRANSMISSION OUTPUT SEAL AN (it cuts off here)
74k miles -
SERVICE: C/S: CUST STATE MILS ON
DESCRIPTION: C/S: CUST STATE MILS ON ~|~C/S: CUST STATE MILS ON ~|~ ~|~15.0 FOUND ENGIN HARNESS BURNT AT ECU CONNECTOR REPLACED HARNESS AND TEST DROVE NO MORE CODES FOUND AT THIS TIME
75k miles -
SERVICE: LEXUS REPAIR
DESCRIPTION: LEXUS REPAIR ~|~C/S: CUST STAES MIL'S ON ~|~ ~|~CHG29E 2.3 T1 8A T2 99 REPLACED AIR INJECTION PUMP, TESTED SYSTEM SYSTEM PASS, TEST DRIVE VEHICLE
Would all these issues scare y'all off, or is this to be expected? There are other smaller things I didn't include, like ignition coils as well.
Old Oct 25, 2019 | 03:42 AM
LFC's Avatar
LFC
Most of the time if the repairs have been made properly I wouldn't be concerned. However, personally I wouldn't buy this this one. Just too many major problems. the engine teardown, the electrical problems, transfer case, etc were each major problems. Not sure if the dealership ever gets the engine back to what a factory new engine would be after a teardown. Also electrical problems on today's complicated vehicles are a nightmare. There are too many nice ones out there to buy this one.
Old Oct 25, 2019 | 06:40 AM
Acrad's Avatar
Acrad
+1 Personally... not one I would be interested in.
File Type: pdf
Old Oct 25, 2019 | 06:51 AM
bbqsoup's Avatar
bbqsoup
What is the price for it? You could get similar one for $18-20k. Unless it is really low. One good thing is the major engine tear down has been going good for 50k miles and more so that’s a good sign.
Old Oct 25, 2019 | 07:42 AM
nuclearn8's Avatar
nuclearn8
Too many non-suspect used GX's out there to settle for this one. pass.
Old Oct 25, 2019 | 09:01 AM
Mistaken's Avatar
Mistaken
I would pass.
Old Oct 25, 2019 | 01:23 PM
dwh13's Avatar
dwh13
Thanks all. Since then, I've decided to look for a 2015 model and spend a little more. My mind changes by the hour on these things I swear!
Old Oct 25, 2019 | 01:31 PM
GoHuskers's Avatar
GoHuskers
This confirmed you are a normal person.
Have Qs then just ask.
epete69
Hybrid Technology
Oct 24, 2022 01:41 PM
fmit1
Apr 2, 2013 06:27 AM
davidber
20
Oct 24, 2012 08:59 PM
LexusSexus
RX - 1st Gen (1999-2003)
29
Mar 21, 2005 09:01 PM
kentchoi
Maintenance
15
Jul 15, 2004 01:25 PM
