Peeling off
The trim on both side of back up screen , looks like fake wood , sotr of.
And around handle used for changing gears from D to R and so on What are you al using as , I guess glue , to re glue it back down ?? Thx |
My wood trim started peeling off near the nav unit. I just super glued it back down. It’s been about 6 months. Temps have gone from 100+ in the summer to -10 degrees in the winter and it’s held up just fine. Hardest part was taking it all apart. |
Taking what all apart ?
The sharp pointy edge next to the nav is barely coming off , really see no reason to take any thing off Super glue , of course , thanks |
Same. The top corner was barely out. I took the piece off because I didn’t want to get super glue all over my dash and nav. I also used a clamp to let it set properly before I put the piece back on. |
I purchased some SG , thanks to you , I am not removing anything , a few drops and hold down for 30 seconds as written in the directions , I might even hold it for a minute .
same with the plastic around the hi low knob |
