Lower Control Arm Cam bolt parts?
Hello All,
I recently purchased an 05 GX470 and I am in the process of replacing the lower control on the passenger front. .
The cam bolts are seized to the bushing so I am cutting the bolts to remove the control arm and I wanted to order new toyota cam parts (Since a lot of people seemed to have issue with aftermarket kits - Moog) . I am a little confused by the parts diagram online since toyota seems to show a couple different parts than the lexus website does. Some of the parts look like bolts but the description says nut instead.
Does anyone know what all parts are needed to replace the cam bolts + other parts that go along with it? Does each of the two ends of the control arm use the same bolt/parts?
I was using mcgeorge toyotas parts website that gives a diagram (looked up an 05 4Runner V8) and then oemlexusparts website that shows a different diagram. For some reason it wont let me upload the diagram.
From the mcgeorge part diagram it looks like i need #
12,48409-60020
Adjust Cam
13,48190-60020
Adjust Cam
14,48452-35020
Lower Control Arm Plate
15,48198-60011
Adjust Cam
16,90105-14104
Lower Control Arm Mount Bolt
17,90178-A0001
Control Arm Nut
19 90170-14026
Lower Control Arm Nut
Any help is appreciated!
12,48409-60020
Adjust Cam
13,48190-60020
Adjust Cam
14,48452-35020
15,48198-60011
Adjust Cam
16,90105-14104
17,90178-A0001
Control Arm Nut
19 90170-14026
See if this diagram helps.
https://www.lexussouthatlantaparts.c...rimLevel=19100
Note that there may be part differences based on whether you have KDSS and your VIN number (Lexus makes changes in mid-year). Your part numbers look correct, but I would stop by your dealer with your VIN to double-check. And ask if they match online prices.
Chip H.
Chip H.
moat
01-12-12 02:09 PM
