Lift time
Lift time
hey guys,
time to lift up the GX, the rear air suspension is giving me grief and rather than mess around with it i figure ill just jump in and convert.
Im thinking of getting this kit from OME as well as the spring isolators and such from metaltech.
https://www.metaltech4x4.com/search....6&category=106
any thoughts on this? would you go a different way? i am having trouble deciding between the heavy and medium.
Truck is stock as of now but will be adding bumpers and such in the future. so debating on putting up with a somewhat stiff ride for a year or so.
thanks,
thanks,
I was considering OME medium but I heard its pretty stiff. Maybe it wouldn't be a problem for you since you will be adding more weight? I ended up on Icon since I can adjust the front coil over if I needed to compensate for front end weight in the future. I went with the SSO rear conversion kit since they have spacers in case I needed more rear lift. Just something think about.
Lexus 4 ME
GX - 1st Gen (2004-2009)
12
02-09-22 11:38 AM
