A T Oil Temp light on - car won't run
12-19-17, 04:24 PM
Pulling in to my driveway tonight on my trusty 110K mile GX and the car shut down. I restarted it and it shut down again, with a red light showing AT Oil Temp on (top left of the dash). Any thoughts on this ?
Thanks
Edit -- my A/T fluid level seems fine. And two other light are on: battery and engine oil light. Some google searches show this may be a bad alternator?
12-19-17, 05:55 PM
Could be alternator, yeah. If you're close to Secaucus NJ, I can swing by with a jump pack and multimeter and look at it for you.
12-19-17, 05:58 PM
Thanks. I have a trusted indy close by and will bring it there. Will let the group know.
12-20-17, 04:19 AM
Today I went to start it and it was having a tough time turning over, like the battery was dying (battery is a year old). So most likely the alternator.
12-20-17, 12:23 PM
That does seem likely. Put a multimeter on the battery terminals when the engine is idling - it should be well above 13 volts. If not, the alternator is toast.
12-20-17, 12:51 PM
Thanks. Car was towed to a nearby indy. They do great work on my BMW. Hoping to have it back shortly!
12-21-17, 01:56 PM
So - was it the alternator? Had mine go bad few weeks ago too and had to get it towed. 3 hrs and $410 bucks later it was fine.
12-21-17, 02:24 PM
Fuel pump died! 110K miles on it. about $450 for the part (OEM) and $300 in labor. Should have it back in a day or so (maybe Tuesday due to the holidays).
Poqman
09-21-17 10:33 AM
stock300
Performance & Maintenance
07-03-12 01:06 PM
95sc300na
03-23-12 08:02 PM
2jz02
11-02-08 01:29 AM
jgm
08-09-07 04:42 AM
