GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Question regarding headlight for 03 GX470
Old 12-06-17, 02:22 PM
Gumobrave
Gumobrave's Avatar
Default Question regarding headlight for 03 GX470
I am trying to replace a headlight and I'm running into so many different model numbers and replacement numbers that my head is spinning. I was told that the product number is 81130-6a240.
I looked and found a nearly identical item by DEPO with this number 324-1110R-US7 that is listed as compatible with this car.
Is there anything I need to know when looking at compatibility issues. I need the non-sport, halogen.
I'm not the most knowledgeable car guy in the world so a little advice would really help. Thanks!!
Old 12-07-17, 12:20 AM
Kalel250
Kalel250's Avatar
Can you post a link to the DEPO ones you’re looking at? Here’s a link to the set I bought and he description I had zero figment issues.
https://rover.ebay.com/rover/0/0/0?m...2F370916236053
Specifications
  • Comes as a PAIR
    • LH (Driver Side) and RH (Passenger Side)
  • Replaces dealer part numbers: 81130-60A60, 81170-60A50, 8113060A50, 8117060A50
  • Smoked/Tinted lenses
  • Includes lenses & housings
  • Built to strict quality control standards
  • Does not include bulbs or wiring
  • Correct for models with Sport Package but will fit other trims
Old 12-07-17, 06:27 AM
chiph9
chiph9's Avatar
Amazon has the Depo units. The non-sport units are:
Amazon Amazon
Amazon Amazon
No idea why they're priced $60 more than the sport ones.
Chip H.
Old 12-07-17, 08:52 AM
Gumobrave
Gumobrave's Avatar
https://www.ebay.com/itm/172977342222
That is the ebay listing. It is a depo part that is supposedly interchangeable with sports specific headllights but it isn't smoked and looks exactly the same as the non-sport depo.
I guess the core question is what is the difference between the non-sport and sport headlights when they are both non-smoked?
Old 12-07-17, 08:59 AM
chiph9
chiph9's Avatar
Sport headlights are smoked.
They probably used a stock photo. Or were lazy when writing their text. Or both.
(I can't follow one of the "VIGLINK" links from work, so I haven't looked at the listing)
Chip H.
Old 12-09-17, 02:39 PM
BlackCat81
BlackCat81's Avatar
The sport headlights fit fine as well, and look better IMO. Keep in mind, myself and several other members on the Facebook group GXOR have issues with the lenses sun cracking. The warranty is only 1 year, and depot would not assist me with warranty due to cracking.
Old 12-09-19, 08:48 PM
JRT3
JRT3's Avatar
..I guess the core question is what is the difference between the non-sport and sport headlights when they are both non-smoked?
Well said....I have this very question as well searching through ebay and amazon listings. I'm sure this has been discussed to death and searching through old posts.
As a "non-sport" owner, I have one headlight that appears perfectly restored and another that still has the haze and appears restored as well. I like the green tint actually and surprise, the originals are not there and mine have a Depo part number. I'm thinking about ordering one new headlight, or ordering the pair of sports.
Options: OEM Sport $600/pair (found a dealer)
Ebay Depo Sport Pair ($300 pair...wrong picture I believe)
https://www.ebay.com/itm/Headlight-H...e/370916236053
Ebay non-sport replacement ($300 each)
https://www.ebay.com/itm/Right-Halog...0/302959017819
There is a big price difference making this a tough call. Open to feedback!
Old 12-10-19, 07:49 AM
captainva
captainva's Avatar
Depo is a reputable aftermarket brand and they make high quality replacements for lots of makes and models. I would feel confident buying Depo headlights for my truck. The aftermarket LED tails I have on my GS are made by them and have been perfect for the last 3 years.
The following 2 users liked this post by captainva:
JRT3 (12-10-19), Lextazy (12-11-19)
Old 03-06-20, 04:51 AM
512TXS
512TXS's Avatar
Here is a DIY on how to replace the headlight as well:
malmon (03-08-20)
Old 10-13-20, 07:13 AM
Turbo4my1j
Turbo4my1j's Avatar
I had ordered some OEM sport lights for my 07 and the dealer cancelled my order because based on the VIN number they say it won’t fit. Is there any difference other then the housing color and reflectors? For the extra $200 I would rather have the OEM then the Depo ones that seem very hit or miss on the reviews.
Or if some are running the Depo ones is there some advice to keep them from cracking?
Old 10-13-20, 07:21 AM
512TXS
512TXS's Avatar
The Depo headlights have been amazing. The only difference that I’m aware of is the black housing on the sport model. Mine is 03 GX and has held up really well. The only regret is that I waited so long to do it.
DIY:
Old 10-13-20, 07:29 AM
Turbo4my1j
Turbo4my1j's Avatar
Thanks for the feedback. The OEM ones were $268 each for the Sport and $425 each for the regular ones. After a small discount the OEM were a little more then the aftermarket which I typically like staying OEM when possible. I just don’t know why the sport ones are much less then the normal ones if they are basically the same. That being said I’m on the fence of the Depo set for about $300 or paying close to $500 for the OEM sort ones. I saw a lot of people interchanging the Depo assembly but I didn’t know about the factory ones being same/different.
Old 10-13-20, 08:05 AM
512TXS
512TXS's Avatar
I didn’t like how my OEM ones had a green tint to it. That and how cloudy it was of course. The Depo black housing to me looks more sporty and the lens is very clear with 5 year warranty. If costs isn’t a consideration, just get the OEM ones ...
Old 10-13-20, 09:21 AM
Lexus4321
Lexus4321's Avatar
I use the Novus 3-2-1 plastic polish kit to keep the plastic looking new. If the lens is chemically changed from bad UV damage or from the heat of a halogen bulb, then polishing is hard to do or not possible. My 2006 has OEM lamps, the plastic can still be polished to almost new look. I did however change to Xenon light system a long time ago.
Amazon Amazon
Old 10-13-20, 01:06 PM
Turbo4my1j
Turbo4my1j's Avatar
https://www.amazon.com/dp/B002UCYRZU
Thank you for the suggestion. What Xenon lights did you go with? Seems that a lot of people like the xenon depot kits.
Quick Reply: Question regarding headlight for 03 GX470
