Best aftermarket Radiator for '06 GX470
Hey guys, looks like I need a new rad for my 06 GX. I could use some input as to what is the most reliable aftermarket radiator on the market today. I hear good things about the Denso radiator: http://www.rockauto.com/en/moreinfo....1432805&jsn=10 but that only comes with a 12 month warranty. Another popular brand is the TYC http://www.rockauto.com/en/moreinfo....432805&jsn=375. This comes with a lifetime warranty and is cheaper. Let me know what you guys think. TY.
Because by now some of them are over 13 years old.
Chip H.
Chip H.
A one-year parts warranty is kind of low-end so far as parts warranties, sure. Ford/Motorcraft and Mopar/Magneti Marelli are offering 2-year warranties on their replacement parts. Honda offers a 1-year warranty.
Chip H.
You misunderstood - Denso is what was put in at the factory. Denso still makes the replacement radiator. Even if you happen across one that's been sitting on a shelf for 13 years (rare) it hasn't been at operating temperatures and pressures, and hasn't been exposed to any UV light. So it'll be just as good as a freshly made one.
Chip H.
Chip H.
I will tell you I bought and installed an all aluminum radiator off of Ebay (insert naysayer comments here) that is produced in China and it came much to my surprise the welds were all good (not pretty in some places) it pressure tested perfectly, I have had it in for about 2 weeks now and about 400 miles in South Texas heat and no issues or leaks. Now I bought an "all Aluminum" radiator because 99% of the time the radiators we have fail on the deal between the "plastic" tank to the aluminum core....probably 99.99% of the time actually... and this will not do that additionally if it does it is rebuildable...unlike a plastic Alum model... for $ 310.00 it is worth it to me!!!
new all aluminum radiator
old Rad cracked on the seam between the tank and the core on the driverside
New one installed, took about 1.5 hours, not too bad at all anyone can do this.
another shot of the installed rad
Maduff3 - you seem brave
I would have been concerned about either fit, quality or even ultimately getting the item if I ordered an all aluminum radiator from E bay, shipped from China. Not to many years ago I would have no way. I bet you have prompted others to think about taking door route.. I just replaced my radiator with the very plebeian Denso 221-312 radiator ordered from Amazon. Think about the contrast between your purchase and mine.
Once I pulled the radiator out and really paid attention to the plastic ends I immediately saw this is as a weakness and that someday expansion and contraction is going to great a problem with this design. So I decided to replace my radiator as a maintenance item knowing the radiator is of suspect design. . I pulled it out and once the fan shroud was off I saw a one inch long portion of the joint oozing.coolant. No problem, just makes me even happier I was replacing. .
that all aluminum radiator was not easy to find and its not cheap. $300
here is the info in case anyone else interested:
http://www.ebay.com/itm/aluminum-rad...-/252810968826
Seller information
winner_racing_internationalhttp://www.ebay.com/itm/aluminum-rad...-/252810968826
GXONE (01-12-18)
Seller information
Should've asked, I could have provided, glad you found it... all good still, no leaks or defects.
GXONE (01-12-18)
