GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Intermittent starting issue
Old 06-22-17, 01:28 PM
gsx750r93
gsx750r93's Avatar
Default Intermittent starting issue
Hey guys, I'm super stumped here and hoping somebody might have a easy fix for me. I'd like to also point out that I have been searching for days on here and haven't been able to come up with a fix. I've found multiple threads where people to have similar issues yet not one seemed to be resolved.
The issue- Intermittent starting/no crank. Seems to only happen after it has been driven for a while. Once you let it sit for roughly 30 min it starts right back up. I let my babysitter drive it and the other day it died on her while running for roughly 20 min. It died and wouldnt start back up until about 40 min later.
So far all I have done is replaced the car battery. I have also bypassed/jumpered the starter relay to make sure it wasnt a starter issue. Starter works fine. I believe I can also cross out the issue of it being a ignition switch. When I am having the issue I test power at the STA fuse and still have 12v so I think I can rule out it being an ignition switch...
What else is left? ECM? Park neutral switch? If it was the park neutral switch would it really do it only once the car warms up and would it cause the car to die?
Any help would be appreciated
Old 06-22-17, 05:58 PM
chiph9
chiph9's Avatar
It's interesting that it died while it was running. If it weren't for that, I'd say the starter is going bad, as the starter on the 2UZ-FE sits in the valley between the cylinder banks, so it gets a fair amount of heat, and heat-soak sounds like part of your problem.
So the "died while running" is either a separate problem, or a symptom. Take a look at your battery cables, especially the ground wires. Sometimes they'll get corroded in the middle of the cable under the insulation, so feel for any lumps.
Chip H.
Old 06-22-17, 06:05 PM
gsx750r93
gsx750r93's Avatar
Thanks for your reply but like I said while I was experiencing the symptoms I bypassed the relay and was able to get it to turn over..
Old 06-23-17, 08:16 AM
chiph9
chiph9's Avatar
Depends on how hot the starter was at the time. If you were pretty quick about bypassing the relay, then yeah, that points somewhere else.
The fun of troubleshooting intermittent problems...
Chip H.
Old 06-23-17, 12:49 PM
gsx750r93
gsx750r93's Avatar
I dont think you understand. Or maybe I dont. For instance im sitting in the truck right now. It will not turn over/crank with the key. If i apply direct 12v to the starter it turns over. That would mean its not the starter correct?
Old 06-23-17, 01:54 PM
Booyah
Booyah's Avatar
Are you putting both Positive/negative onto the starter terminals? If so and its starting then I think like mentioned above you need to look at the positive and especially the negative cables that attach to the engine block (negative cable) that cable being slightly messed up will cause you all kinds of issues--especially when its HOT, cause the resistance goes way up.
My friend had a toyota truck (older) and his did the same thing, installed a new starter (no good) then he went to looking at cables and found the Negative degraded. After replacing this cable he has no issues, yes his truck acted up only when hot, would start fine when cold...
Old 06-23-17, 02:16 PM
gsx750r93
gsx750r93's Avatar
Im removing the starter "STA" relay and jumpering from the 12v wire to the wire that goes to the starter. Simply bypassing the relay.
Old 06-23-17, 03:16 PM
chiph9
chiph9's Avatar
Do you have all three keys for the truck? (two with remotes, one wallet key)
Does it start right up using one of the other keys?
Wondering if it's an immobilizer issue.
Chip H.
Old 06-23-17, 03:30 PM
gsx750r93
gsx750r93's Avatar
I have all 3 keys. Im letting it sit now and currently it wont start. Im gonna give it another 30 min and will see if it will start with one of the others. One thing I do know is the security light turns off when the key goes in the ignition only with one of the keys. The primary one we use.
Old 06-23-17, 03:38 PM
gsx750r93
gsx750r93's Avatar
Also for what its worth there has been a few times where the car would turn over like 3 seconds after I let off the key from the "turn over" position which seems odd.
Old 06-23-17, 05:51 PM
EddieK05
EddieK05's Avatar
Have you had the codes read? If not, I'd try that too to try and eliminate some head scratching.
Old 06-24-17, 09:10 AM
gsx750r93
gsx750r93's Avatar
No I haven't. I assumed since we have never had a check engine light go off that there wouldnt be any codes.
Old 06-25-17, 10:37 AM
gsx750r93
gsx750r93's Avatar
No codes and now im stuck at the auto parts store. Maybe the neutral safety switch? If it is bad will it still show what gear it is in on the dash? So when i am experiencing the problem and try and turn it over the dash lights dont go out. I thought I read somewhere that if the lights dont go out that it indicated the nuetral safety switch is bad.
Old 06-25-17, 10:56 AM
gsx750r93
gsx750r93's Avatar
Just eliminated the ignition switch as a problem. The nice thing is they let me return it.
Old 06-25-17, 12:07 PM
NTH
NTH's Avatar
I would look into the negative/ground cable as already suggested and replace starter relay.
Quick Reply: Intermittent starting issue
