GX470 lift points
GX470 lift points
Hi, has anyone worked on the GX470 using a lift before, I am trying to determine the picture vs actual spot on the frame.
I know the front should be the same spot you put jackstand too, is this where you put the your jackstand normally.
The rear lift location is a little harder to understand, I think it is referring to the spot just before the 4 link bracket. Using those points should be fairly equal distance from the wheels.
I don't have a pic, but there's a stamped steel circle shape on the skidplate under/behind the engine showing where the crossmember is, this is the front jacking point for if you want to put jackstands under the front frame rails.
Thanks Ian. This is what I was looking for.
I actually removed the skidplate and placed the included jack under the crossmember shown in the diagram and it put a good size indention in the crossmember. Very disappointing. I hope I didn't f anything up. Does anyone know on this forum know where to pick this thing up without damaging it?
