GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
No sound from speaker, is it blown?
Old 09-13-15, 05:10 PM
SC3coupe
SC3coupe's Avatar
Default No sound from speaker, is it blown?
Last week while listening to the radio I hear a scratchy noise in the back driver side door follow by hissing then silence. I thought my tire or air bag had a leak but found nothing.
Today I found that door has no sound coming out of the speaker so that must have been related to what I heard.
Those that had to replace the speaker did you completely get no sound at all when "blown"?
I have the non nav unit not sure if there is an amp for my system?
Old 09-13-15, 09:32 PM
SC3coupe
SC3coupe's Avatar
Turns out the speakers have sound had to put ear to the grill to hear it, at low volume almost seems like the sound is from the front
Old 09-14-15, 05:02 AM
BlackCat81
BlackCat81's Avatar
Mark Levinson sound? Chances are you've torn a speaker surround on one of them. Check online for surround repair kits, they're cheap and easy to do. The door panel is a breeze to pull off as well.
Old 09-14-15, 05:08 AM
SC3coupe
SC3coupe's Avatar
I do NOT have the ML sound.
The fader and balance are zero.. since only the front has tweeter maybe that's how things sound until it turns up loud enough. Have to test the decibals to see if one is quieter than the other in the back.
would a torn surround sound obviously bad?
Old 09-14-15, 07:01 AM
techrep
techrep's Avatar
Yes...it would sound like what you described.
Old 09-14-15, 07:42 AM
chiph9
chiph9's Avatar
Depends on how bad the surround is torn, but yeah.
There are repair kits that are way cheaper than replacing the speaker.
Chip H.
Old 09-15-15, 03:56 PM
jpnut
jpnut's Avatar
Chip H.
Can you please provide some links?
Old 09-15-15, 05:17 PM
IanB2
IanB2's Avatar
The speakers in my Land Cruiser had zero intact surround remaining after 23 years, but they still put out audible sound, just really lacked mid-low range output. If you've got nothing but hissing/no sound, you've got bigger problems than just the surround IMO. The tweeter would still work just fine, it doesn't sound like you've got even that. I'm going to say blown voice coil, or (hopefully not) an issue with the amp/headunit. I'd do some further diagnosis before spending any money on a repair kit.
Maybe pull the speaker in question and hook it up to the speaker leads for one of the other doors, and try another speaker in the "blown" door to make sure you know what component failed.
Old 09-15-15, 07:48 PM
LexRex
LexRex's Avatar
You can look at the speaker in question and you'll know right away if it's blown. That won't rule out additional problems though. In my experience, a blown speaker usually has an obvious rattling, distorted sound, particularly at higher volumes.
Old 09-16-15, 07:16 AM
chiph9
chiph9's Avatar
A quick google search found this one for the 4.5" speakers. There are other kits available for the 6x9" and smaller speakers.
Amazon.com: Toyota / Lexus / Mark Levinson 4.5" Speaker Surround Repair Kit - 86160-05W00: Electronics Amazon.com: Toyota / Lexus / Mark Levinson 4.5" Speaker Surround Repair Kit - 86160-05W00: Electronics
Chip H.
hsmac
02-17-16 06:20 AM
webmouth24
03-07-12 09:25 PM
alanchad
12-17-09 11:22 PM
Quick Reply: No sound from speaker, is it blown?
