GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Steering shimmy when warm only
Old 12-29-14, 06:01 AM
chrisvr6
chrisvr6's Avatar
Default Steering shimmy when warm only
I have a slight shimmy at around 68-70 and that disappears when its cold out, (20°today) . Was thinking the power steering fluid thickens? Anyone else?
Old 12-29-14, 06:13 AM
chiph9
chiph9's Avatar
Does it change based on the outside temperature, or the engine temp? And what happens after you've drive it for a while?
Chip H.
Old 12-29-14, 07:02 AM
nipponbird
nipponbird's Avatar
It cannot be ruled out that it has to do with the viscosity of the power steering fluid, but do you have this shimmy on all road surfaces? The fact that you mention a specific speed, points to wheel balance.
Old 12-29-14, 09:41 AM
chrisvr6
chrisvr6's Avatar
Only when its cold outside. All surfaces same speed range. I will flush power steering fluid first. Wondering if Toyota calls for a specific brand?
Old 12-30-14, 08:33 AM
chiph9
chiph9's Avatar
For power steering fluid, I would use the Toyota brand.
Chip H.
Old 12-31-14, 08:05 PM
YoshiMan
YoshiMan's Avatar
Make sure you use the dexron type automatic transmission fluid, and not actual "Power steering fluid"... Toyotas have never used that stuff.
So it shimmys when is IS cold, or shimmys when it is warm out?
My guess is it's something tire related, if it responds to temperature changes.
Old 01-05-15, 05:40 AM
chrisvr6
chrisvr6's Avatar
Steering shimmys when its warm. Its fine when its cold.
nparthi
02-03-19 08:04 PM
dbui
RX - 1st Gen (1999-2003)
07-03-13 04:30 AM
hlu1
IS - 1st Gen (2001-2005)
02-22-13 11:53 PM
cgreenberg
10-06-10 06:27 PM
TheMole
Maintenance
07-31-08 11:00 AM
Quick Reply: Steering shimmy when warm only
