2003 GX Running Boards
Hello everyone!
I just took the running boards off my GX and will not be needing them ever again. I was wondering if anyone would be interested in purchasing them. I don't know what the rate would be, maybe some of you could help me out in that department. Let me know if you are interested and we could work something out. Thanks -Patrick |
I'll be removing mine before my next offroad trip with buddies (the kinds with rocks that will break them off). Just curious, how long did it take for the complete removal? Just want an idea so I can carve out a weekend slot in between family time.
Originally Posted by Fluid
(Post 8525783)
Remove the power connector. Open front and rear doors. Remove all the snap fasteners at the bottom of the door frames. I think there's a Phillips head screw at the front end of the board that has to come out (can't remember for sure). Remove the bolts from the "L" brackets - the one's holding the board to the brackets. Leave the chassis ones on. Pull the board off. Remove the "L" brackets. Weather-proof the connector and cable tie the wires up out of the way. Repeat on other side. Getting the snap fasteners out is the hardest part! (I now have a tool to do it.) Don't bother with plastic trim removal tools. The snaps will break them. METAL screwdriver and needle nose pliers work. |
Originally Posted by 470reasons
(Post 8526661)
Figure about an hour.
