Replacement of Trans oil on GX
#61
you got it on the bolts. Check this thread out on the GS350. Same procedure with the jumper wire. I did my wifes GS350 and replaced 3 quarts at a time until I did 12. Would do 3 and refill, start for 2 seconds and do 3 more, etc until got 12. Then did the jumper procedure to top off. Note: he did 3 and then drove and did more later. I did all 12 in same procedure.
https://www.clublexus.com/forums/gs-...iy-w-pics.html
#62
I looked at mine today and its pretty small.I cound not read anything..lol. I am going to buy a magnifying glass..
#64
Thanks burny!!!! I do not see many people saying that they are replacing the trans filter,are most NOT doing that?
Either way I may do mine.Part of the exhaust pipe is in the way but the bolts are all kinds of rusted,so,I doubt I will be able to get them off.I may have a trans shop do the filter change and the first drain and fill and then I will do 2 drain and fills after that. Thoughts?
#65
I have to be honest with you. I have never replaced a transmission filter. I have a 91 4runner I bought brand new and it still has original filter in it. I am pretty good about keeping everything on an aggressive maintenance schedule. Clean fluids may make the difference.
#67
around 270,000. Still has original starter and alternator shells. I have just rebuilt them 3 or 4 times. Just changed fuel pump for first time at around 225k. That was a job as tank had to be lowered.
#72
Sewell's parts lexus with CL discount is $6.88 http://lexus.sewellparts.com/accesso...2009/4372.html
#74
Price for Toyota do change the trans fluid is $600.00. Service guy said they do not reccomend it of course. He said they drain and fill it 3 times. He made it sound like it was a big issue because there is no dip stick and they had to hook a scan tool to the diagnostic plug. He also asid the WS fluid is expensive.I wonder what Lexus is going to tell me...
#75
nuts man, just nuts. My local Toyota has a dedicated WS fluid machine and wanted around $200 which included 12 quarts of fluid. For that price I may let them do 2 of my vehicles when the time comes. I did the GS350 and it is not a bad job at all with 2 people.. For around $100 labor, I would let them do it if they let me watch. lol
