GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Old 12-12-14, 03:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Rear Shock Replacement With Toyota 4Runner OEM Replacements
Old 08-26-17, 10:09 PM
  #61
FlexyLexi
FlexyLexi's Avatar
Just replaced the rear shocks with 4runner shocks as described in this post. Shocks were only $31 each and with shipping the total was <$80! The ride wasn't that bad before but occasionally I would hit the bump stops on speed bumps. So far it seems like this did the trick-that hasn't happened since. It rides probably on the stiffer/ "sport" side of the adjustable suspension now, which is fine with me.
One tip-don't even bother trying to get the bolt off from the top. Just cut it off. Also, make sure you are feeling patient when you do this...mine were rusted and took quite a bit of prying even after I chopped off the nut. Otherwise it was all very straightforward. Also I couldn't get some of the old washer off of the old shocks, so I bought a couple stainless washers and just used those instead. They aren't rounded to hold the bushing nicely but I don't see why it should make much difference so I just went for the easy solution.
jonnyyaa
NX - 1st Gen (2015-2021)
02-24-19 02:11 PM
BlueES
19
03-09-15 12:20 AM
Muti007
04-24-13 12:32 AM
UTGS400
01-20-06 11:20 AM
Quick Reply: Rear Shock Replacement With Toyota 4Runner OEM Replacements
