GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Trailer Lights, Need Help!
Old 03-30-12, 04:58 PM
zippymbr
zippymbr's Avatar
Default Trailer Lights, Need Help!
Well I can't get the turn signal and break lights to work on my trailer. The running lights work. I know the lights on the trailer work they work hooked up to another truck. The hitch was installed by the dealer and the 7 pin connector is all plugged in like it should under the GX. I boughtbthe GX used, ist an 06. I pulled out the DMM and am not getting any voltage at the 7 pin connector except for the running lights. I checked for any missing relays and see 2 but can't find the third one I have read about. I am stumped, I am using a standard 7 pin to 4way converter I bought at an auto parts store. It has led lights on the outside that show if the lights are working. Only one of the 4 light up.
Any advice would be great.
Old 03-30-12, 05:42 PM
BurgBoxstr
BurgBoxstr's Avatar
start by checking the 2 connectors underneath (behind the 7 pin faceplate female plug) by the spare tire. There are supposed to be 2... sounds like the 4pin one may be disconnected.
look at the second picture here for reference:
http://lexus.sewellparts.com/accesso...2004/4364.html
Good luck
Old 03-30-12, 07:12 PM
zippymbr
zippymbr's Avatar
I checked both of the connectors coming off the 7 pin under the GX both were tight.
Old 03-30-12, 07:31 PM
kphu
kphu's Avatar
there is also a relay in the left back trunk area behind the leftside panel. Also 2 relay in the engine compartment
Old 03-31-12, 05:29 AM
zippymbr
zippymbr's Avatar
I've looked but can't find that one
Old 03-31-12, 04:55 PM
zippymbr
zippymbr's Avatar
I have found all he relays and they are all installed and the connections are tight. Still nothing but running lights.
74jeepguy
05-06-17 03:23 PM
ZCP
08-01-15 04:46 PM
geoJwD
09-02-08 02:34 PM
noelleon
Lighting
01-01-06 04:21 AM
es3doubleO
Lighting
01-30-05 07:18 AM
Quick Reply: Trailer Lights, Need Help!
