LED drl for gx470
I was trying to do a search for you, but couldn't find it. Someone installed the Mercedes led's in the space/ opening below the headlights in the front bumper. It is in the opening where there is a black plastic grill. I believe they may have bought them from Xenon Depot. Here is a link
http://www.kbcarstuff.com/SearchResu...neBy_1434=7939
Here is another link to a youtube video
http://www.youtube.com/watch?v=jI_YMPxpXIs It shows were the led's were placed in the front bumper
looks like crap unless it's part of some body kit made by a reputable vendor like wald int'l. also can't stand it when it's not a bright white LED light. so many barney lights out there it's rather embarrassing imho.
You dont need to add external DRLs as that will alway look crap , But you can mod the existing DRLhalogen bulb currently used to LED type by modding the Flasher unit which is below the Driver Side fuse box. All you need is the add a potentiometer flow control by turning the screw on the potentiometer to regulare the voltage ) and voila you have LEDs bulbs to your DRL and your Turn Light Bulbs
You dont need to add external DRLs as that will alway look crap , But you can mod the existing DRLhalogen bulb currently used to LED type by modding the Flasher unit which is below the Driver Side fuse box. All you need is the add a potentiometer or a resistor to control the voltage flow by turnning the screw anti clockwise that is to regulare the voltage. This mode to be done on the circuit board of the flasher unit ) and voila you have LEDs bulbs to your DRL and your Turn Light Bulbs
