GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
surging transmission
Old 09-05-11, 02:48 PM
jbdvm1988
jbdvm1988's Avatar
Default surging transmission
my 2006 GX has 95000 miles and recently i've noticed a slight hesitation followed by a slight surge in speed while driving at a constant speed. it almost feels like i'm pushing the accelerator then releasing it. its a very mild difference but i'm guessing tranny and have 5k left on my warranty. any thoughts. it occurs at a variety of different speeds but most noticeable at about 35-40mph and up around 55mph.
Old 09-06-11, 09:07 AM
mann777
mann777's Avatar
You can do the following which will bring a huge change in your Acceleration Hesitation issues, and Engine Response.
Have the following bought.
1. Air Filter
2. CRC Air Flow Sensor Cleaner ( Schuks - $6) ( to remove deposits
3. Valvoline SynPower Carb, Choke, and Throttle Body cleaner [$4 from Schuck's]
Thats it. As you have 95k miles, it will be ideal to do with the Air / Oil Filter Change
Synopsis:
OVERVIEW
Why: to remove deposits on the MAF sensor, and carbon deposits on the throttle body that rob the car of fuel economy, power, throttle response, and idle smoothness
Air Filter - P/N 17801-50040 ( Sewell )
Ventilation Valve - 12204-50030 ($8.64) Sewell
Cost: $10 in parts [CRC MAF cleaner ($6)
Valvoline Carb, Choke, & Throttle body cleaner ($4)]
Required Time: 30-45 minutes. One of the easiest task to do if you are a Grease Monkey.
Result: smoother idle while in gear and parked, better fuel economy, and more immediate, instant throttle response.
Important Note:- BEFORE YOU START--ALWAYS DISCONNECT THE BATTERY, AND IF THE ENGINE IS HOT, ALLOW IT TO COOL DOWN BY REMOVING THE ENGINE COVER OVERHEAD WITH THREE BOLTS.
Start with the MAF Sensor Cleaning,( pretty important dont touch anythin within those sensors and they break away. and then have the Air Filter Replaced then target the Throttle Body and then replace the Ventilation Valve.
cheers
Old 09-19-11, 05:27 PM
jugdish
jugdish's Avatar
being mechanically retarded, is this something we can have done at either a lexus dealer or a mechanic, and will they know what we are talking about?
Old 09-26-11, 09:52 AM
mbenz80
mbenz80's Avatar
When I took my engine apart at 256K miles to replace the heads, carbon deposit was excessive in intake manifold. I used MEK (methyl ethyl ketone) to clean (wash) it off. Same goes for the throttle body.
Later, when I had the previous owner take it for spin, he could feel smoother idle and a lot better throttle respond right a way. He was the one that put 210K miles on the clock in less than 6 years of ownership.
All sensors are still original (oxygen, knock, maf), engine is running "sweet" and transmission is shifting perfect.
Old 09-28-11, 08:15 AM
aljodoro
aljodoro's Avatar
Default Man777
Thanks so much.
Two questions:
1. Where is the maf sensor located in the GX470
2. There seems to be some discussion on the cleaner to use. Specifically not to use some of the commercial MAF sensors.
Here is a post from an earlier formum posting
Yes you are right the MAF type in Lexus is equipped with Karman type Mass Air Flow Sensor, which uses a moveable mirror and transistor to measure the Air Flow wake within and the trasmittor sends signals to the ECM to adjust the air flow appropriate the idle speed required. I have heard the best is to Spray 99% pure isopropyl alcohol (available at electronic stores) onto the wires to clean and shake dry. Be careful not to use other solvents as they may damage the sensor. The MAF sensor also incorporates the intake ambient air temperature sensor so it’s a good time to also give that a quick wipe with cotton which is soaked in the above liquid air spray.
__________________
I see you are recommending the CRC cleaner. Are you on the isoproply or CRC side? Looks like the CRC but want to make sure. Your advice is always so welcome. Thanks
Old 09-28-11, 12:18 PM
BurgBoxstr
BurgBoxstr's Avatar
Originally Posted by aljodoro
Thanks so much.
Two questions:
The MAf is on the intake tube just aft of the air filter on GX. You'll see it pretty much plain as day - held in w/ 2 Phillips-head screws.
CRC MAF cleaner is the right choice. Discussion most often seen regarding MAF cleaning is if generic Electronic cleaner is OK to use or not. To which I say get the MAF version as you can always use MAF cleaner on other electronics but I wouldn't trust regular electronic cleaners on MAF (film residue possibility). The potential to save < $10 (on cleaner) is greatly exceeded by the replacement cost of a MAF - a couple hundred $$...
Good luck
Old 09-28-11, 09:35 PM
aljodoro
aljodoro's Avatar
Default Thank you
great help on this forum
Gs46046
01-20-24 12:16 PM
mitmaks
02-26-12 06:23 PM
NinaMR
RX - 1st Gen (1999-2003)
05-09-09 05:31 AM
UNOHOO
13
12-16-08 08:01 AM
spxChrome
03-05-03 09:35 PM
Quick Reply: surging transmission
