Deciphering driver's mirror cabling... please help
I'm attaching a page from the GX470's wiring diagram. It shows the Outer Rear View Mirror Assembly connecting to its ECU with the connector carrying 9 cable signals
MR+
MR-
LMVR
LM+R
LMHR
VSSR
LE1
HSSR
LVC
Does someone know what each of the abbreviations stand for?
Very very gratefull for any light you can shed on this !
Thank you,
Nikolas
MR+
MR-
LMVR
LM+R
LMHR
VSSR
LE1
HSSR
LVC
Thank you,
Nikolas
i recently depinned and the repinned both of my mirrors because i replaced the stock mirror covers with LED directional covers. what a pain in the buttocks that was! sadly i couldn't tell you what any of those abbreviations stand for. all i know is that i did it successfully.
Got it from techinfo.toyota.com. If I remember correctly, there was a wiring diagram from '05 onwards. Could this have changed from tht model year onwards? I expect the markings would still apply, no?
my pics as proof of what i did. all i know is that i screwed them up the 1st time around and luckily hadn't touched the other(driver side) so i had a reliable reference to work with.
ok maybe the 2005 onwards had a dual ECU for the mirrors. I am not aware of that. The codes which you have mentioned abbreviation in general, but they are color coded to connect the ECU ,Mirror Tilt Motor. But i do know the three codes in those that is MR+ = Mirror Positive Wire , MR - = Mirror Negative Wire and LMHR = Left Mirror Heater Wire.
roman1
10-17-17 03:42 PM
GRAND_LS 4
04-23-16 05:32 AM
Purple350
01-22-15 08:28 PM
